Suggestions on fixing plywood side
Forum topic by BB1 posted 09-02-2017 08:08 PM 655 views 0 times favorited 20 replies Add to Favorites Watch
View BB1's profile
BB1
1167 posts in 963 days
09-02-2017 08:08 PM
I am continuing to work on a mudroom laundry hamper holder. I have the box completed and have gotten my plywood edging on the front and back glued in place. At some point (apparently) I tore the bottom of one side of the plywood. I do plan to paint this portion. Is there a way to repair the tear out to create a solid surface for painting? As can be seen in the picture, it isn’t much, but would like to make it right if possible before painting. Thank you.
20 replies so far
View JoeinGa's profile
JoeinGa
7739 posts in 2122 days
#1 posted 09-02-2017 08:15 PM
Since you’re gonna paint, just use wood filler (putty) and sand smooth
View Ripper70's profile
Ripper70
1112 posts in 1024 days
#2 posted 09-02-2017 08:18 PM
If not spackle/joint compound, perhaps a thin strip of trim. It’ll hide the imperfection and possibly prevent it from happening again.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View Kazooman's profile
Kazooman
1115 posts in 2068 days
#3 posted 09-02-2017 08:23 PM
Agree that wood filler should do the job. Timbermate is a great product.
I doubt that the damage is from tear out on the table saw. You would have noticed that I am certain. I bet you dragged the box across the bench or shop floor. I have seen that cause the veneer to catch and tear out somewhat, although not quite as badly as yours.
View GR8HUNTER's profile (online now)
GR8HUNTER
4541 posts in 828 days
#4 posted 09-02-2017 08:29 PM
BONDO :<))
View BB1's profile
BB1
#5 posted 09-02-2017 08:40 PM
Thank you for the suggestions!
Since you re gonna paint, just use wood filler (putty) and sand smooth
- JoeinGa
Had thought of that. I just have never had good experiences with wood filler but those were situations where it would “show” rather than being under paint. That may be a good first option to try.
If not spackle/joint compound, perhaps a thin strip of trim. It ll hide the imperfection and possibly prevent it from happening again.
- Ripper70
The trim is something I had considered originally but then I did not create my top with as much overhang as I would like to fully trim the box. Still considering for just around the bottom if I can find a way for it to “fit” with the leveling feet. This is where having a fully developed plan would be helpful (I did not…sigh…the struggle of the weekend woodworker with limited experience!).
- Kazooman
You guessed it. Pretty confident that I had all clean cuts. The box was heavy and in moving it around to assemble, I’m pretty sure I did the tearing. Lesson learned -ask for help when I need it.
View Jim Jakosh's profile
Jim Jakosh
21105 posts in 3221 days
#6 posted 09-02-2017 08:44 PM
You can use a good wood filler or wood glue and fine sawdust as a putty!.
View BB1's profile
BB1
#7 posted 09-02-2017 08:54 PM
You must have read my mind…”do I have any wood filler around?” I have some Tightbond Quick & Thick Multi-surface Glue which says it is paintable. Might be an option. Thankfully this is on the side that will be toward the wall so fixing the edge is more for my pride than for what others will see!
- Jim Jakosh
View oldnovice's profile
oldnovice
7115 posts in 3483 days
#8 posted 09-03-2017 04:57 PM
A little late note!
If you use Timbermate and you are going to paint with latex paint, you will need to seal the Timbermate otherwise the latex paint will soften the filler.
Haven’t tried it but I assume that oil based paint would not soften the Timbermate!
View BB1's profile
BB1
#9 posted 09-03-2017 06:02 PM
Thanks for the tip. I ran out of time yesterday to deal with the repair so not too late! I may try Tightbond glue (which I have on hand) – assuming that will be ok with any paint as it states “paintable” on the bottle.
A little late note!
Haven t tried it but I assume that oil based paint would not soften the Timbermate!
- oldnovice
View jbay's profile (online now)
jbay
2582 posts in 1015 days
#10 posted 09-03-2017 06:06 PM
I wouldn’t mess with anything else but bondo.
It’s going to be the best bet in my opinion.
I’ve used it quit a bit under paint.
View BB1's profile
BB1
#11 posted 09-03-2017 06:20 PM
Additional option -thanks!
I wouldn t mess with anything else but bondo.
It s going to be the best bet in my opinion.
I ve used it quit a bit under paint.
- jbay
BONDO :<))
- GR8HUNTER
View Woodknack's profile
Woodknack
12329 posts in 2495 days
#12 posted 09-03-2017 06:41 PM
Glue will shrink. Bondo is fine but messy and stinks. Spackling or drywall mud would be easiest. No smell, dries reasonably fast, cheap, sand s easily. Just don’t get the gimmicky kind with granules in it, sometimes marketed especially for repairs.
View BB1's profile
BB1
#13 posted 09-03-2017 08:14 PM
Thank you for the suggestions. I looked at it some more and see the tear is right on top of a void. I think, given the depth, that I’m going to try to incorporate a thin trim strip.
Glue will shrink. Bondo is fine but messy and stinks. Spackling or drywall mud would be easiest. No smell, dries reasonably fast, cheap, sand s easily. Just don t get the gimmicky kind with granules in it, sometimes marketed especially for repairs.
- Rick M
oldnovice
#14 posted 09-04-2017 05:09 AM
Ricky M, you keep say spakling or dry wall mud!
If you ever get a chance to try Timbermate, please do as it has the same properties as spackle except for the color and the fact that dry leftovers can be reconstituted and used again. The colors can be mixed to match every wood you can think of.
As you can tell, I like Timbermate and have used it in place of the typical oil based rub your arm off fillers ever since I first tried it. I have even used it to replace some missing grout which I matched so well you can tell where the grout ends and the Timbermate begins.
I belive that the MSDS is also similar to spackle!
View theart's profile
theart
45 posts in 670 days
#15 posted 09-04-2017 03:05 PM
Is this going to be anchored to the wall? If it’s free to move around the laundry room, you’ll get more tearouts later. A trim strip or a beveled edge would be the way to go.
