Lapping a Hand Plane
Forum topic by Manitario posted 01-20-2011 10:33 PM 4194 views 0 times favorited 11 replies Add to Favorites Watch
View Manitario's profile
Manitario
2606 posts in 2789 days
01-20-2011 10:33 PM
Topic tags/keywords: plane
I just inherited a couple of hand planes from my grandfather and am trying to tune them up to get into the magical world of hand planes. I’m just curious what is the best way to lap the soles? The planes I inherited have been heavily used over the years and the soles are scratched and almost certainly no longer flat. I have seen a number of different ways that people use, from using abrasive powder on a glass plate to using a belt sander to using hand files.
Any suggestions or comments on what has worked for people?
As well, there is a small amount rust on the cap iron and cutting iron for on of the planes. Has anyone had any success using some of the advertised liquid rust remover or is my best bet to use a wire brush to remove the rust?
Thanks!
11 replies so far
View DonH's profile
DonH
495 posts in 2724 days
#1 posted 01-20-2011 10:54 PM
Hi Manitario
I would suggest you obtain a flat surface (MDF stair tread would work and be cheap too) put adhesive backed sandpaper on it and some mineral oil and away you go. I would suggest starting at 180 grit and work your way up to around 400 grit. Make sure the iron is installed and tightened up to working pressure (just over finger tight). This will ensure the plane body is conforming to its working shape.
For rust removal WD40 or any appropriate commercial product should work – I use 0000 steel wool to apply it and work out the rust. The result is a nice finish with smoot transitions from any painted areas to the bare metal.
Good luck!!!
Don
-- DonH Orleans Ontario
View DonH's profile
DonH
#2 posted 01-20-2011 10:57 PM
One additional comment
The plane iron should have the back flattened by the same method you flatten the sole. Once that is done, flatten it again on your 1000 grit stone and work through the grits to your finest stone – now you can sharpen it.
Make sure your stones are flat as well – there are various ways to achieve that but I suggest you check out robcosman.com and look at some of his videos. To make a blade sharp it has to be flat and the stone or other material used must also be flat. This is an often overlooked point.
Don
View swirt's profile
swirt
2551 posts in 2878 days
#3 posted 01-20-2011 10:58 PM
Evapo-rust will tackle the rust with no problem.
Don’t assume the sole is not flat just because it is old and well used. If your grandfather flattened them, they may still be flat. Check it out with a known flat surface… or a known straight edge.
If it needs flattening, I’d use wet dry sandpaper stuck to a known flat surface (glass, granite surface plate, table saw wing, jointer bed…) Be sure that the frog (the thing that holds the blade) is secured in place with the blade and chip breaker all locked in too, just retract the blade so it is not protruding. Cast iron flexes a bit so it is important to have the body be under the normal tension it will be experiencing while you are flattening it.
If it is significantly out of flat, use a belt sander belt cut open and adheared to a known flat surface. The extra length will allow you take longer strokes while flattening.
View Bertha's profile
Bertha
13508 posts in 2600 days
#4 posted 01-20-2011 11:04 PM
I have nothing to add to the above. It’s exactly what I do, however, I use a piece of marble windowsill instead of the MDF; use dilute Murphy’s Oil Soap instead of mineral oil; and use an electrolysis tank and PB blaster/wire brush for rust removal. But the idea remains exactly the same-ultraflat surface and increasing grits. Plan to spend a good bit of time lapping the back of the iron. If it’s too pitted, you may want to opt for a replacement blade. Don’s right that a dished stone will prevent you from getting the edge you want. Personally, I’d stay far away from belt sanders and especially files (except for maybe taking down a peaked ding).
Welcome to the wonderful world of planes!
View Broglea's profile
Broglea
682 posts in 2997 days
#5 posted 01-20-2011 11:22 PM
Rob – That’s some good advice you’ve been given. I don’t really have anything to add. The process of restoring a plane can be just as satisfying as using a well tuned plane. Have fun.
View crank49's profile
crank49
4029 posts in 2877 days
#6 posted 01-21-2011 12:46 AM
Only thing I could add is to be sure and work through the grits. If you start out too fine, like with 400 grit, you will get frustrated with the slow process. I start with 150, go to 220, then 300, 400, then 600 to 800 and finish on 1200. It only takes about 2 or 3 minutes on each grit once you have your edge angle and flat back defined. I don’t use a stone at this point, I just lap it on a leather strop band on an expanding rubber wheel I borrowed from my jewelry manufacturing process, everyone has their own little tricks. But the main thing is, if you start too fine, or skip over some steps, it can take hours to get the same results you could have gotten in about 15 or 20 minutes.
A jig or fixture to hold the iron (blade) at a consistant angle when you start to work on the edge is a good thing to have. I got one at Woodcrafter for about $10 and I really like it. I have done this without a guide for years, but the consistancy really speeds the process up.
Good luck.
swirt
#7 posted 01-21-2011 02:40 AM
Bertha, that’s interesting about the murphy’s oil soap…. is there a reason you prefer it?
View steopa's profile
steopa
60 posts in 2696 days
#8 posted 01-21-2011 11:13 PM
Hey Rob, not sure if you saw it, but the latest Woodcraft magazine (which showed up in my mailbox today) has “Put Grandpa’s handplanes back to work – page 26” on the cover. I haven’t checked out the article, but seemed right up your alley.
-- Steopa
View HorizontalMike's profile
HorizontalMike
7747 posts in 2820 days
#9 posted 01-22-2011 01:53 AM
FYI—Found black granite flooring tiles at HD for ~$4.50
crank49
#10 posted 01-22-2011 05:58 AM
Mike, I use those 12” x 12” black granite tiles myself. Best surface I’ve found for $5.00.
Manitario
#11 posted 01-22-2011 06:21 AM
Thanks for the tips. I have one of those black granite tiles from HD that I use to sharpen my chisels on, it possibly was the best thing I’ve ever gotten from HD for $5. Lapping the cutting irons has been the relatively easy part so far; it is lapping the sole of the planes that I’m not looking forward to, as some preliminary work showed me that this is going to be a lot of work. Crank49; you’re right about not using fine grits to start; I tried starting with 220 grit and realized that I’d be lapping for months.
Steopa: thanks for the heads-up; I’ll have to check the article out.
