Installing Accuride Full Extension Zinc Box Drawer Slides
Forum topic by Sawdustmaker posted 228 days ago 1460 views 2 times favorited 4 replies Add to Favorites
View Sawdustmaker's profile
Sawdustmaker
254 posts in 282 days
228 days ago
I’ve been building a mobile chop saw stand and the end is in sight. One hurdle that I have yet to clear is the installation of my drawer slides. I’ve bought a set of the Accuride Full Extension Zinc Box Drawer Slides and the instructions are a little vague. (at least for my drawer skill level) Installing them on the carcass seems straight forward enough, and then it gets kind of cloudy on how to proceed. The instructions call for you to separate the slide parts. My question is, how does one align the slide piece that attaches to the drawer? I looked for awhile on the net looking for the skill info I’ll need and have found lots of info on how to build drawers, but very little on how to install the slides. I’ve been eyeballing the Jig it on Rockers’ site and wander if it’s worth the twenty bucks and if it will solve the problem as it only shows marking the carcass and not the drawer. I have not found much looking at the search feature here either. I’m open for suggestions, directions. Thanks
-- Brian, Virginia Beach
View GaryK's profile
GaryK
8483 posts in 473 days
228 days ago
1. Measure the height of the opening and the drawer.
2. Subtract the drawer height from the opening height.
3. Divide that by 2 to get you your even spacing for top and bottom.
4. Measure from the bottom of the opening to the center of the drawer slide.
5. Subtract the number from step 4 by the number you got in step 3.
6. Use that number measure up from the bottom of the drawer to mark the center line of your slide.
View Iffy's profile
Iffy
24 posts in 410 days
228 days ago
The Wood Whisperer has a video online where he installs the drawer slides on his assembly table. Seemed to help for me.
http://thewoodwhisperer.com/episode-19-assembly-table-stand/
View Catspaw's profile
Catspaw
104 posts in 300 days
227 days ago
I’m lazy. I use blocks at whatever height to space up the carcass side of the slide and screw them in. I put the inner slides back in. Slide the drawer back in almost all the way. Use 1/8” shims to shim up the drawer (make them long enough to hold the drawer level.) Pull the inner slide out and mark the height. Take the drawer out and scribe it. Set the slide back the appropriate amount on the drawer side and screw it in. no math, no fail.
-- arborial reconfiguration specialist
Sawdustmaker
227 days ago
Well, thiis all helps demystify the install. I may have to give you 1/2 the credit for this project Gary. Thanks all for the info. —Brian
Bookmark And Share This Page
