Sealing Knots for Painting
Forum topic by JHuttIII posted 09-01-2017 08:03 PM 457 views 0 times favorited 3 replies Add to Favorites Watch
View JHuttIII's profile
JHuttIII
2 posts in 383 days
09-01-2017 08:03 PM
Recently bought our first home at the beginning of the year, and our Master bedroom needed a complete overhaul from head to toe. Everything is pretty much complete now with the exception of the trim/molding, which I removed too as it was in bad shape. I have all of the wood necessary (just using Pine), but am having difficulty finding a good method to not have any knots bleed through the paint.
When I rebuilt the closet threshold (did an expansion), I used a technique I found on YouTube by professional painters which entailed applying a couple layers of a bondo sealer over knots before priming. After about 3-4 coats of Kilz latex primer though, the knots still bled through. I was pretty shocked as I wasn’t expecting it to come through the Bondo layer.
After some further research online, what I have come up with now is to apply wood filler to the knots, then apply a couple of coats of BIN shellac primer (aerosol) before putting on my regular primer for the wood.
I rarely paint the wood I work with, so I don’t have a lot of technique down for this. Any help or guidance here would be most appreciated!
3 replies so far
View jdh122's profile
jdh122
1033 posts in 2933 days
#1 posted 09-01-2017 08:41 PM
Shellac is about the only thing that works. Personally I don’t bother with a shellac-based primer, but rather put actual shellac over the knots (once they’re filled with wood filler). It dries in about 30 minutes, then use regular primer and then paint.
-- Jeremy, in the Acadian forests
JHuttIII
2 posts in 383 days
#2 posted 09-01-2017 09:08 PM
Thanks for the reply. I was wondering if regular shellac or the BIN shellac primer choice would matter much. I hear a lot of people swear by the BIN stuff, but not sure if one would be better over the other.
woodbutcherbynight
5545 posts in 2524 days
#3 posted 09-02-2017 02:01 AM
I have taken the router to the offending knot and then glazed back over it with bondo.
