| Forum topic by willie | posted 281 days ago | 667 views | 0 times favorited | 13 replies | ![]() |
281 days ago |
Topic tags/keywords: bandsaw I am a newbie to the bandsaw world. I need some guidence on choosing the correct blade for the right job. I recentely bought a Grizzly 14” saw for the main purpose of doing some resawing. I have been using a 1/2” 6 tooth hook blade that came with the saw. Question? What should I be looking for in order to tell when the blade is to dull to keep using? If I need to replace the blade, where can I find the most bang for the buck when it comes to finding the best blade for resawing? |
281 days ago |
Hi Willie… Another great reference is “The Bandsaw Book”. Look for it on Amazon. Sincerely, Tom -- Anybody can become a woodworker, but only a Craftsman can hide his mistakes. |
280 days ago |
Thanks Tom, can you tell me, what is the method that gives the more accurate results, using a fence, pivot point or freehand? I have been trying to use a fence and have had mixed results. The cut starts out good, but within around 4 inches or so, the cut is the correct width on the top of the board, but the blade wanders to the left and the cut becomes paper thin at the bottom. I have checked and rechecked my setup as best as a rookie can at this point. I am attempting to cut some 1/4” thick veneer from 3/4” thick stock by 8” wide. Any tips you can provide would be very much appreciated!!!! |
280 days ago |
Ditto what Tom posted. Let me recommend http://thewoodwhisperer.com/ Look at episode 13 on setting up a bandsaw. Mark does a pretty good job with this topic. -- With God's help all things are possible- even woodworking. Woodworking is not just a hobby, it is an (expletive deleted) expensive hobby. |
280 days ago |
The fence adjusted for the blade drift is the easiest, but the hardest to get setup right. The pivot method works good, but you have to keep a close eye in it while cutting. Freehand is only good if you are making real rough cuts. It’s hard to keep the board straight up and dowm. Get some good blades. I like the Wood Slicer by Highland Hardware. You can see my review of them -- Gary, East TX -- The longest journey begins with a single step. |
280 days ago |
Check out this Band saw sled by Bob#2 Search on Lumberjocks for some other re-saw postings. -- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN. http://www.woodcarvingillustrated.com/gallery/member.php?uid=3627&protype=1 |
280 days ago |
I use a small (10”) bandsaw for my boxmaking. |
280 days ago |
Willie… First off, from what you are saying, I’d either susspect that the blade does not have enough tension or the guides are not close enough. With the saw unplugged, kick up the tension a little and check your spacing for the guide blocks. I use a dollar bill as a spacer for the blocks. As for the rear bearing, I get it as close as I can without it touching. This ensures that when I apply pressure with the wood, it is there for support right away. As for technique, Each blade has its own drift angle. That is, based on the makeup of the saw, it has a tendency to deflect a little left or right. Start with the blade you intend to use and no fence on the table. Take a squared up Piece of scrap plywood “3/4 works well”. Using a square, draw a line parallel all along the longest edge about an inch or two from the edge. Plug your saw back in and start to cut that line you drew. About half way through the cut, you will notice the angle you need to hold to get a straight cut in the plywood. STOP CUTTING and hold the board in place. Stop the motor and wait for the blade to stop. Using a graphite pencil, draw a line directly on the table, along the edge of the plywood. This is your drift angle! Remove the board and set up your fence, measuring the face of the fence to the blade for your thickness of cut and that the face is parallel to the drift line. Practice this a few times and it will all come together. Remember, each blade and eack set up can produce a different drift angle and you’ll need to check it after any adjustments. Hope this helps… Sincerely, Tom -- Anybody can become a woodworker, but only a Craftsman can hide his mistakes. |
280 days ago |
I am a big fan of PS wood blades and I believe that the secret is in the guides. The difference a set of cartr guides can make is huge. Also, please odn’t be in a rush. Let the blade do the work and you will get good results. -- making sawdust.... |
280 days ago |
Hey Willie, Tom -- Anybody can become a woodworker, but only a Craftsman can hide his mistakes. |
277 days ago |
I have recently upgraded my Shopsmith 10 inch bandsaw with the Kreg fence and resaw pivot. This is a beautiful system that even includes a micro adjuster. -- "Heaven is North of the Bridge" |
277 days ago |
I bought a Woodslicer based on GaryK’s review. I have not used it yet because my band saw is in my unheated garage. I was getting fair results with a three tooth 3/4” blade from Grizzly. I did the Carter bearing upgrade. -- Maplewood, MN |
277 days ago |
I too bought two Woodslicer blades on GaryK ’s review and have yet to use them. Cheers -- A mind, like a home, is furnished by its owner |
275 days ago |
I have an earlier version of the Kreg Bandsaw fence and resaw guide, both designed by Mark Duginske. They are both available at Woodcraft. Not cheap, but with a properly tuned bandsaw and the 1/2 inch 4 tooth skip blade it works like a dream. -- Gerry |
| Sponsor | Forum | Topics |
| Become a sponsor |
Woodworking Skill Share
1363 |
| Become a sponsor |
1810 |
| Become a sponsor |
124 |
| Become a sponsor |
379 |
| Become a sponsor |
111 |
| Become a sponsor |
Woodworking Trade & Swap
252 |
| Become a sponsor |
Coffee Lounge
1020 |
| Become a sponsor |
LumberJocks.com Site Feedback
286 |
