Stanley no 8 Jointer plane - updated x 2 now with pics
Forum topic by kent_michaels posted 01-20-2011 05:17 AM 17690 views 0 times favorited 27 replies Add to Favorites Watch
View kent_michaels's profile
kent_michaels
34 posts in 2565 days
01-20-2011 05:17 AM
Topic tags/keywords: question plane
Hello, I’m hoping to get a little help from someone a little more knowledgable about stanley hand planes. I have an opportunity to buy a Stanley number 8 Jointer plane that is in really good condition, no rust, handles are tight, etc. The seller wants $75 for it, is that a good price? I’m VERY new to using handplanes and just happened to met a guy with a no 8 he wants to sell. Any help or info on the price would be great.
Thanks
UPDATE:
I just looked at the plane. It’s actually a Stanley 8C. Maybe a dosen or so eraser sized spots of surface rust. Handles are very tight and solid, blade, chipbreaker all parts look great on it. There is some white paint that has been splatterd on the top of the plane, about a 10 minute clean up job. I can’t seem to find any dates stamped on the plane however, if this is a later model is it still worth $75 or should I pass? Also japanning seems at least 95%. Thanks for info.
I now have the plane in hand, here are some pics, still have not fully committed to purchase, through a little quick research I believe this to be a type 16 1933-1941…correction it may be a type 19 as Stanley is written on the lateral adjustment…never tried to accurately date the age of a tool before! The 19 was 48-61
27 replies so far
View Dave's profile
Dave
11426 posts in 2713 days
#1 posted 01-20-2011 05:35 AM
check this out it will help a lot
plane resources
View bigike's profile
bigike
4053 posts in 3162 days
#2 posted 01-20-2011 05:36 AM
Man i’ll tell u this if you don’t get it i will just let me know the guy so i can get pics. LOL ;)
View Chris 's profile
Chris
1879 posts in 3864 days
#3 posted 01-20-2011 05:55 AM
That is a pretty darned good price just make sure the casting isn’t cracked. You may need to invest in a new blade but you won’t know that until you get it. I would go for it. I got mine for about 30ish and have not regretted it at all!
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
kent_michaels
#4 posted 01-20-2011 05:57 AM
I’m going to be inspecting the plane this friday, from the pictures I was shown and from what the seller told me (he’s a pretty straight shooter) the only thing this plane needs is for the blade to be sharpened, didn’t even look like the handles hand any wear on them. Thanks for the responses and thanks for that link Dave, tons of info there!
View swirt's profile
swirt
2508 posts in 2845 days
#5 posted 01-20-2011 06:15 AM
That is not a bad price at all. Sure it is not a miraculous garage sale find, but it is in line with what they sell for on ebay and you can see it before you buy it. Even a “cheapo” Anant is more than twice that
http://www.highlandwoodworking.com/anantkamalno8jointerplane.aspx
View Loren's profile
9767 posts in 3521 days
#6 posted 01-20-2011 06:16 AM
That’s an okay price. I’ve seen them for $50 OR $60 here and there.
View Cantputjamontoast's profile
Cantputjamontoast
416 posts in 3306 days
#7 posted 01-20-2011 06:41 AM
if a lot of the iron is not let there may be room to dicker.
Pinnacles were on sale. The #8 iron is not made by everybody
-- "Not skilled enough to wipe jam on toast!"
View knotscott's profile
knotscott
7820 posts in 3249 days
#8 posted 01-20-2011 02:21 PM
That could be a good price depending on age, type, condition, etc. Need some specific info or good pics.
View blackcherry's profile
blackcherry
3336 posts in 3696 days
#9 posted 01-20-2011 03:20 PM
Most time that’s what they sell on ebay in bad condition, if this one is in ready shape it a very fair price…BC
kent_michaels
#10 posted 01-21-2011 05:46 PM
swirt
#11 posted 01-21-2011 06:35 PM
This can help you date it.
http://hyperkitten.com/tools/stanley_bench_plane/
Either way, unless it has plastic handles (indicating it is really new), it is probably worth the $75 … if you need an 8. If you are not planning on doing much hand jointing, then you may not need an 8.
#12 posted 01-21-2011 07:18 PM
You may find a #8 too-heavy for comfortable use, but if you want to
give it a go I don’t think you’ll get hurt buying at that price. You should
be able to resell the plane for the same later if you don’t find you use
it much.
I like the corrugated planes, personally. In some cases the corrugations
add some value to collectors, but mostly with the Bedrock planes I think –
which is a big generalization.
View b2rtch's profile
b2rtch
4847 posts in 2922 days
#13 posted 01-21-2011 07:48 PM
Who is going to push this beast?
I have a#7 and I am a strong man and this is already not piece of cake to use.
-- Bert
Chris
#14 posted 01-21-2011 08:01 PM
I personally have a #8 Pre-lateral that I use quite often; For the asking price I think it sounds like a good deal.
View rwyoung's profile
rwyoung
409 posts in 3345 days
#15 posted 01-21-2011 08:41 PM
@Loren & @b2rtch you guys probably already know this but for the benefit of others:
1) Don’t expend effort lifting the whole lane up to return to your starting place. This isn’t for finished surfaces so just roll it up on an edge a touch and pull back. Yes, you can drag it back flat BUT there is considerable debate on how this can dull the iron. Easy enough just to roll up and slide back.
2) Use your the big muscles in your legs to push it. Keep it sharp and waxed, using the muscles in your arms and shoulders only to guide it. If your workbench is at the right height it is pretty easy.
I’ve got little bitty chicken wing muscle arms and I have no problems hogging through material with a scrub, fore and jointer then smoothing for hours at a time.
What I don’t have is a #8 but I’d like to add one sometime. Couple of #7s, 6’s, 5’s 4’s and 3’s each one set up a little different than the other. Makes things pretty efficient and still takes up less space than a stationary jointe & planerr. :)
-- Don't sweat the petty things and don't pet the sweaty things.
