272 days ago
btw… sorry for the “War and Peace” – it’s late and I really should be sleeping and not posting on the internets.
Darned stream of consciousness.
-- - living vicariously through lumberjocks
272 days ago
Or you could use Norm’s FAVORITE TOOL, the brad nailer! I’ve never seen anyone shoot as many brads or nails into the finished product as Norm. Plus I have never seen him apply finish to any project or fill any nail holes. Personally I’d just drill some pocket holes, screw the face frame on and then plug the holes with those special plugs that they sell for pocket holes of the pocket holes show.
I don’t know if I’m picturing this correctly, but you are going to just make some shelves with no back and hang it on the wall of your closet? What are you going to attach the second piece of the french cleat to with no back to the unit without it all showing? If it was me, I’d put some 1/4 inch ply on the back to hold everything square and hide the french cleat.
-- Jim
272 days ago
i have actually seen norm apply finish , he probably has some flunky like me fillin the holes during commercials LOL i think your idea will work but if your doing the carcass all the way around i dont see a need to do the faceframe all around you could just do it at random places like near the corners and 1 or 2 between depending on the size of your frame ive used the kreg p h plugs but only as a decorative feature if im doing a maple project i might use walnut plugs to me they look pretty cool my 2 scents
272 days ago
I record every HGTV DIY show that comes on during the weekends. Has Norm ever finished a project? I see how he shows the major steps in construction, but I never see a finish project or sometimes other key elements of construction. I also don’t really care about his last 10 minutes of his show running off somewhere to show me something useless.
Also, I’m wondering how I can make biscuit joints for a few projects that I’m considering. Including a closet system. I was thinking about using my router with a proper bit (that I might have to purchase), but I don’t think they will penetrate deep enough. How much is a decent biscuit joiner? I like his idea because it means no nails showing on the front.
Note: When you install a closet system, often you already have baseboards in your closet. What would you recommend, removing the baseboard and cleaning up the drywall, or designing your shelving system to go around the baseboards with a cutout?
272 days ago
Hmm.. Good point mrtrim – if that’s the case I could just do stopped grooves randomly around the face frame.
I’m not so concerned with the pocket holes showing – I just figure it would be less time consuming to just set in some biscuits, glue and clamp it and call it a day. Otherwise as much as I like pocket screws (I’ll be putting together the face frame with them) it’s just a bit tedious. As for the French cleat showing, that doesn’t bother me much either.. It’s going in my own closet and overall with the pre-finished plywood, it’ll be words better than what my closet looks like now (just a closet rod and a wooden shelf above it.) The inside of the closet is painted the same mustard color as my bedroom walls, so I was just going to paint the cleat to match as well and it will all be covered with folded clothes anyway. But if there’s a structural reason that’s compelling enough, I’ll throw some ply on the back.
cpt_hammer – a decen biscuit joiner is at least $80-100 – another LJ posted recently about a good buy he made of a Freud joiner for $80 and that in reviews it finished middle of the pack – the good ones were $180-200. It’s not so much the cost of the joiner in and of itself – it’s just that I’m already going to be shelling out for the router, probably a router table or at least the materials to build one and a basic router bit set. Didn’t want to shell out another $100 on top of that for the biscuit joiner if I could avoid it this time around. Obviously it’s good for many things and will come in handy when I use it for it’s intended task. I just think I can get by without it.
As for your comment about the closet baseboard – this is exactly why I chose to hang mine off the wall. The bottom shelf on mine actually ends up about 12-15 inches off the closet floor – so I don’t interfere with the baseboard, and it should be easier to keep clean underneath if I can pass the vacuum in the whole floor of the closet.
272 days ago
Ok people… I see where this is going. DON’T MAKE THE SAME MISTAKE I MADE! If you are going to use biscuits, just get a biscuit jointer.
I have tried the continuous slot method. It works on the plywood side, where it goes into the edge of the plywood, because the “side grain” of the biscuit meets the “side grain” of the ply. But it doesn’t work on the face of the other wood because the grain is not oriented properly and it is not strong enough. You need individual slots for that side just like Norm did it. The only advantage to doing a slot on one side, is to save the set-up time of aligning the slots.
As for alternatives to a biscuit jointer, I have tried that too. That Craftsman router/biscuit jointer kit is a joke and you will only be frustrated… and besides, its almost half the price of a biscuit jointer. Believe me, don’t bother. Just get the ”right tool for the right job.”
Besides, when I finally got my biscuit jointer, I used it SOOOOOOOOOOO much. I love that thing for quick, easy cabinetry. It is a tool worth investing in.
-- Check out my new website! http://www.theeasellife.com
272 days ago
I second what Blake said!
272 days ago
Blake (and GaryK)
Good stuff – thanks for the explanation – I figured there had to be a good reason why I hadn’t seen it done this way before. Just what I was looking for..
Now the next question – what biscuit jointer should I get? :-)
272 days ago
I use the Dewalt, but they are all basically the same.
272 days ago
I agree with Blake and Gary. A biscuit joiner is a one time purchase, and you will get many years of service out of it. It is so quick and handy that you will likely not even notice it as part of your work.
272 days ago
I’ve got a Porter Cable that I paid (I think) around $200 for about 1 year ago, believing that I really needed it. Now I’m not so sure.
I suppose, like anything, it has a learning curve that I’ve yet to summit but I’ve noticed that there is a slight, but annoying, amount of slop, allowing misalignment between the faces or edges of 2 pieces of wood that were both registered to the fence side if the biscuit jointer. This alignment is exactly what I thought the tool would help provide but it seems not all is well in the real world. Heck, I even read the manual!
I haven’t used it very much because of that, but my last few projects could have been done with it or without it. I went without. I haven’t thrown in the towel quite yet but I haven’t found it indispensable, for sure.
-- The secret to creativity is knowing how to hide your sources. Albert Einstein
271 days ago
I have a Dewalt and like Marty experience the slop. I use it only on long glue ups.
-- If we learn from our mistakes, I'm getting a fantastic education.
271 days ago
here are the Reviews (only 1 so far, though)
271 days ago
BJoiners rock. I love mine, it makes things so easy. But…. you could route the grooves/slots and use a spline like in the old days. I built several cabinets before biscuits or Kregs and used this method.
Iron on veneer tape works great also (heck, it’s a closet).
271 days ago
Thanks Steve.. I’m seriously considering the veneer tape. In my limited experience with them in the past, I can see sweaters and other clothes getting caught on the tape. But after doing a cost benefit analysis – I can see them making sense – particularly if they’re much improved from what I have experienced 15+ years ago.
271 days ago
i get woodworking journal and the last magazine had a good review on the Ryobi if you are just giving it once in a while use. it only costs 100$. if you are giving it frequent use it recommended the Porter Cable biscuit joiner for around 200$. it also has a attachment which allows it to be compatible with mini biscuits.
271 days ago
Like the teenage woodworker, I’d steer you toward the Ryobi. I bought mine – I dunno – eight years ago and am still waiting for it to die so I can replace it…
-- Tom's Workbench - http://tomsworkbench.com
271 days ago
I’ve got the Ryobi and the Dewalt. I’d recommend both, or either.
