Wipe-on poly
Forum topic by Deglazed posted 01-19-2011 05:36 AM 1867 views 0 times favorited 9 replies Add to Favorites Watch
View Deglazed's profile
Deglazed
18 posts in 2716 days
01-19-2011 05:36 AM
I was discussing with a fellow LJer about minwax wipe-on poly and how there is only satin or gloss. Some projects need a middle ground. Is there anything wrong with mixing the two 50-50 to achieve semi-gloss?
-- ~tomorrow should see more working and less figuring
9 replies so far
View richgreer's profile
richgreer
4541 posts in 3099 days
#1 posted 01-19-2011 05:47 AM
I do it all the time and I really like the results.
Deglazed
#2 posted 01-19-2011 05:59 AM
Thanks Rich. Saves me from sampling on fire wood! I lose enough on projects already.
View Roger Clark aka Rex's profile
Roger Clark aka Rex
6940 posts in 3459 days
#3 posted 01-19-2011 06:12 AM
Rich:
Have you ever used Minwax Water Based Wood Stain Clear Tint Base?
IS it any good when used with a powdered dye?
-- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time.
richgreer
#4 posted 01-19-2011 06:34 AM
Roger – the short answer is “no”. I seldom use stain and I never use dyes.
View Gregn's profile
Gregn
1642 posts in 3008 days
#5 posted 01-19-2011 05:07 PM
I thin down my poly for wipe on and have had good results. Just a thought I’d throw out there.
View Dominic's profile
Dominic
34 posts in 2917 days
#6 posted 01-24-2011 12:49 AM
There is an article in this months Popular Woodworking dealing with finishes, with a section all about polyurethanes in their various glosses. The glossiness of a polyurethane depends on the amount of flattening agents it contains, withe lass glossy containing more flattening agents. You can increase the amount of flattening agents by adding satin to gloss without a problem.
-- Dominic P.- Duxbury MA
View tswoodwizard's profile
tswoodwizard
104 posts in 2715 days
#7 posted 01-24-2011 01:54 AM
Wow Barry; Thats a very well thought out precess, I’m assuming you’ve experimented with this a lot. Your a valuable member of LJ. I bet I’ll end up using that a lot.
-- Tim B. Sweely Elizabeth, Illinois, timsweely@yahoo.com -------- My potential is limited only by my emagination.
View Rick's profile
Rick
9725 posts in 3057 days
#8 posted 01-24-2011 06:59 AM
As Gregn has said Thinning a Regular Poly of whatever Sheen with Water has also worked for me.
Last Wipe On I did was Satin Poly mixed 50/50 with Water. One of our “Chemists” on here who is Very Conversant with All Finishes suggested it.
Considering the Price of Wipe On as compared to Regular Poly I think it’s the way to go. I’ve also done it with Semi Gloss, worked fine.
Rick
-- LIFE is what happens when you're planning on doing Other Things!
View hObOmOnk's profile
hObOmOnk
1381 posts in 4152 days
#9 posted 01-24-2011 10:45 AM
Adding small amounts of rottenstone to your varnish will calm the gloss.
Test before committing.
-- 温故知新
