Bubbles in Water Poly
Forum topic by richardchaos posted 08-27-2017 08:08 PM 538 views 0 times favorited 6 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 582 days
08-27-2017 08:08 PM
No matter what I do I keep getting many tiny bubbles in my Water Based Ploy using a foam brush? How can I get that fixed?
NO I DONT SHAKE THE CAN! I stir gently
The Poly is a well known Water Poly from Lowes
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
View Kazooman's profile
Kazooman
1239 posts in 2155 days
#1 posted 08-27-2017 08:36 PM
Foam brushes vary quite a lot. You can get a decent brush with dense foam and get good results. You can purchase a cheap foam brush with really coarse, open foam and generate a million bubbles. One thing that can cause bubbles is pressing too hard so that you are essentially squeezing the finish out of the brush. Any trapped air blows out the pores in the foam and makes bubbles. A gentle touch really helps a lot.
Why not purchase a really good quality bristle brush? Clean up of water based poly is a snap and the brush should last a very long time.
19448 posts in 2059 days
#2 posted 08-27-2017 09:07 PM
+1 to the above. That can happen with a foam brush. You can usually remove them by finishing up with only the weight of the brush for final strokes.
View Lazyman's profile
Lazyman
2636 posts in 1590 days
#3 posted 08-28-2017 03:41 AM
Almost impossible to prevent bubbles in poly with a foam brush. I use a high quality natural bristle brush anytime I use either water or oil based poly because you get a much nicer results. Also, don’t try to apply too much finish in each coat. Better to do several very thin coats than a few thicker ones. Another option is a wipe-on poly. It will require more coats but will yield the smoothest, most natural result.
View TungOil's profile
TungOil
1059 posts in 697 days
#4 posted 08-28-2017 03:56 AM
+1 on the wipe on. I gave up on brushing varnishes years ago, never could get a satisfactory result with them. Or if the project is small enough, get a rattle can and spray it.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View Carloz's profile
Carloz
1147 posts in 794 days
#5 posted 08-28-2017 03:57 AM
I always shake the jar with poly very well turning it upside down at times to distribute the dulling agent evenly. I never get bubbles in the finish. It is an urban legend.
View Rich's profile
Rich
3882 posts in 792 days
#6 posted 08-28-2017 04:07 AM
+1 on a bristle brush. I get bubbles, and find that waiting a few minutes and doing a soft drag with the brush at close to 90º wipes them out. Another thing that works for smaller surfaces is to go back and dab the bubbles with the brush to pop them. Either way, the finish levels out pretty well in the end.
