Cheap Pipe Clamps and not so SQUARE!
« back to Hand Tools forum
Forum topic by richardchaos posted 08-27-2017 02:27 PM 916 views 0 times favorited 12 replies Add to Favorites Watch
View richardchaos's profile
richardchaos
583 posts in 407 days
08-27-2017 02:27 PM
I bought some equipment from LOWES last week. Some 3/4 pipe clamps and a Sliding square. Three of the clamps were not THREADED! and the Square was not SQUARE!
Is it really too much to demand squares be square and the pipe clamps be machines to screw onto a pipe??
IS that really too much to ask!????
-- “In a time of universal deceit, telling the truth is a revolutionary act.” ― George Orwell
12 replies so far
View JackDuren's profile
JackDuren
388 posts in 987 days
#1 posted 08-27-2017 02:57 PM
- richardchaos
You didn’t check? I never buy a square without checking it. Never assume…
richardchaos
#2 posted 08-27-2017 03:39 PM
- richardchaos
You didn t check? I never buy a square without checking it. Never assume…
- JackDuren
I DO NOW!
JackDuren
#3 posted 08-27-2017 03:59 PM
You are not alone…..I did the same thing with a framing square. I bought, got home used it, and found out it wasn’t square…
View Drevo's profile
Drevo
9 posts in 912 days
#4 posted 08-27-2017 05:36 PM
Are the pipe clamps Irwin, by chance? The newish Irwin clamps are designed to be used on non-threaded pipe.
Just a thought.
View PaulVan's profile
PaulVan
1 post in 293 days
#5 posted 09-03-2017 03:31 PM
One of the more important things I learned a few decades ago was how to check a carpenter square for square and then how to correct the tool if not. The square can easily be knocked out of square by improper use, storage, or dropping.
117126 posts in 3605 days
#6 posted 09-03-2017 03:43 PM
I went to a box store and took a whole pile(8 framing squares) over to the lumber department to check for square, not one was square.
woodbutcherbynight
4876 posts in 2436 days
#7 posted 09-03-2017 05:06 PM
Really not surprised. As far as the square is concerned I am guessing you are speaking of a carpenters square. These are inexpensive and are intended for generic carpentry use. Think framing and such. They can be off and it hardly matters. For furniture grade projects where absolute square is needed these are so so. They can be made square as another poster stated. For many years this was the only square I ever had and it worked, mostly. BEARPAW set me straight on getting more precision out of my work by utilizing combination squares, and set up of machinery by using machinist squares. It does make a difference. Several manufactures of decent to high end combo squares exist. I was given a Starrett by my Father few years back. Normally out of the price I would pay but free is always best. It is a excellent square and when such exacting precision is needed this is my go to square. Other less expensive units exist and can be found for much cheaper.
My .02 cents worth anyway.
Special thanks to those who posts and offer explanations and tips on improving accuracy. I have learned alot over the years from this site from such posts.
View Rarebreed68's profile
Rarebreed68
147 posts in 329 days
#8 posted 09-03-2017 05:47 PM
I started buying from The Yard Store when I was working on aircraft cabinets. The squares they sell have always been dead on accurate and reasonably priced.
http://www.yardstore.com/precision-measuring-tools/squares.html
-- EARTH FIRST! We'll log the other planets later. Trust your neighbors, but brand your calves. Opinion worth price charged.
View splintergroup's profile
splintergroup
2077 posts in 1250 days
#9 posted 09-04-2017 02:33 PM
You are not alone…..I did the same thing with a framing square. I bought, got home used it, and found out it wasn t square…
- JackDuren
The two things to test at the store before buying are levels and squares (any square, especially those long drywall squares!).
A quick test for levels is to place it on a straight surface (vertical or horizontal), note where the bubble meets the markings, flip it (end for end), then verify that the bubble is in the exact same position.
richardchaos
#10 posted 09-04-2017 03:03 PM
I think that before the fall of ROME all their squares and levels were not square and level!
runswithscissors
2768 posts in 2053 days
#11 posted 09-07-2017 12:53 AM
Not only that, they had to use Roman numerals to do all their engineering.
View avsmusic1's profile
avsmusic1
272 posts in 713 days
#12 posted 09-07-2017 02:34 PM
Did you buy assembled pipe clamps, or the pipe clamp hardware and the pipes separate? If the latter, most of the hardware stores near me will thread the ends for you on the black pipe – Home Depot did a bunch for me
