| Forum topic by steliart | posted 882 days ago | 3777 views | 7 times favorited | 22 replies | ![]() |
882 days ago |
Topic tags/keywords: storage plywood storage plywood sheets small workshop cad shelves
I am in the process of looking for a space to build in my new workshop. Here’s what I came up with for plywood and MDF storage. The storage system is an upright design and can hold up to 18pc of 6×8 foot sheets. It’s mainly constructed by plywood and 2×4s and is on casters. It’s been hold onto the wall with a metal water pipe system that allows it to pivot away from the wall, and its footprint is 80×28x108” with the shelves, without the 6 shelves it’s 80×17x108”. The shelves are about 72×12” There’s a PVC pipe rolling system under the plywood base for easy roll-out action and it has 3 long clamping removable lumbers for keeping the sheets flat. Hope you like it and maybe get some new ideas out of it. -- I am not so rich to buy cheap tools. |
22 replies so far
#1 posted 882 days ago |
I like the PVC pipe rollers. Not sure I get how it can pivot away from the wall. Seems like the shelves would hit the wall before it turned very much. Good overall concept. -- Joe |
#2 posted 882 days ago |
The pipe can be a bit longer if you like, but this will give you a 45 degrees clearance to remove your sheet and roll it back in place. Also it depends on which wall you are mounting it, the vertical one or the horizontal behind it. So its flexible. -- I am not so rich to buy cheap tools. |
#3 posted 882 days ago |
One more thing. If the space is too tight you can always make a 45 degrees cut from the far edge od the shelves. That will give you even more pivoting angle. -- I am not so rich to buy cheap tools. |
#4 posted 882 days ago |
looking good so fare thank´s for sharing the idea |
#5 posted 882 days ago |
The PVC rollers may not work well if you have more than one sheet. Either all your sheets will want to move if the rollers turn or if the other sheets present enough weight and friction then the rollers won’t turn to remove one sheet.You might think about using UHMW strips instead of the rollers. I use them and sheets slide as smooth as glass. Just a thought. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#6 posted 882 days ago |
I always say that two heads are better than one and shipwright prooved me right because he is right. UHMW is inpossible to find here but there is another way around this problem. Instead of having a hole pipe as a roller you can have lots of 3/4 circles with a washer between them so that they act and move independently. -- I am not so rich to buy cheap tools. |
#7 posted 882 days ago |
Ok I think this correction will set things right now. -- I am not so rich to buy cheap tools. |
#8 posted 882 days ago |
that was quick thinking :-) Dennis |
#9 posted 882 days ago |
I think you might be happier with the UHMW rather than all those individual rollers. When you start loading different thicknesses of sheet goods and saw dust starts dropping in and you don’t get the back of the sheet as tight as the front of the sheet and (insert any number of other issues) . . . Also, I understand from your description, that the rack is somehow attached to the wall and pivots on axis. So long as that is correct, that will work fine as long as the casters can take the load. HOWEVER, if the rack is not attached securely to the wall, I would be most concerned about it tipping over. With just a few full sheets of plywood or MDF, you will find that it will weigh enough to severely injure or even kill someone onto whom it might fall. I’d hate to see that. Sincerely, I don’t want to sound all gloom and doom. I like the layout and the concept. I store my sheet goods in a similar layout but mine does not pivot. My bottom plate has a sheet of UHMW and the sheets slide in and out with no problem, even if I’m picking from the middle. And I figure that if it gets worn out at some point in the future, I’ll either just turn the other side up or put a new sheet in. Cheers! -- Dave; Lansing, Kansas |
#10 posted 882 days ago |
FirehouseWoodworking has a good point in the push stack area, need to address this problem. Understand that UHMW would be the best solution but is unavailable over here and most companies don’t ship internationally and if they do it costs 3X+ untill it gets here. I will keep searching if I can found anyone in Europe whos willing to ship in my country. -- I am not so rich to buy cheap tools. |
#11 posted 882 days ago |
My PW storage rack has only three or four 1” strips of UHMW and it works very well. I don’t believe it would be any easier if it were solid. You really don’t need much. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#12 posted 882 days ago |
Thank you shipwright -- I am not so rich to buy cheap tools. |
#13 posted 881 days ago |
One other thing I noticed is that you don’t have much headroom over the sheets. When you put sheets in or pull them out that will be a problem as you will almost certainly be tilting them in and out. You can do the math or measurement but I think you will want a minimum of about the hypotenuse of a 2’ x 8’ triangle for inside height. -- Paul M ..............If God wanted us to have fiberglass boats he would have given us fiberglass trees. http://prmdesigns.com/ |
#14 posted 881 days ago |
Looks great!.... I agree with Dave, my only concern is whether it would be top heavy. Be very careful rolling it around. the base appears to be too narrow for the high weight of the plywood. I hope I’m wrong! -- Buzz ---- Message sent from the End of the Internet. |
#15 posted 881 days ago |
Clever swivel on the wall. My suggestions: - Consider a Square rather than rectangular. Seems that You’ll quickly fill up what you’ve designed. I’ve got 4 ROLLING TOOL TOWERS. You can even store sheetgoods on the legs that stick out for the casters, that’s what I did. Or build a short version and you could make use of the top. -- Backer boards, stop blocks, build oversized, and never buy a hand plane-- |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3594 |
15981 |
Hand Tools
2098 |
Jigs & Fixtures
501 |
Wood & Lumber
2908 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
