Equipment SAFETY tips: The Table Saw
Forum topic by MsDebbieP posted 854 days ago 1982 views 0 times favorited 45 replies Add to Favorites Watch
18320 posts in 2329 days
854 days ago
Topic tags/keywords: safety table saw
Safety in the shop tips; for the table saw.
What are some tips to work safely on and around a table saw?
(See all SAFETY TIP GATEWAYS here)
45 replies so far
View ellen35's profile
ellen35
2441 posts in 1601 days
#1 posted 854 days ago
Never, EVER, lose your concentration!
View rance's profile
rance
3856 posts in 1329 days
#2 posted 854 days ago
1) Don’t touch the spinney thing.
2) Keep the blade, miter slot, and fence exactly parallel.
View Uncle_Salty's profile
Uncle_Salty
181 posts in 1242 days
#3 posted 854 days ago
Raise blade height to 1/4” taller than the stock to be cut.
Never, ever cut “freehand” on the table saw.
When ripping, use a push stick on stock less than X” (depends on your comfort level; I tell my students to use a push stick if the stock is less than the width of your hand with the thumb extended, but my safety test reads 6”).
Always use a Splitter/kickback pawl when ripping.
In general, never use a miter gage and the rip fence together to cut a piece of wood (There are exceptions to this… thus the term “in general”).
View stefang's profile
stefang
9462 posts in 1503 days
#4 posted 854 days ago
1. CONSISTENTLY FOLLOW THE BASIC SAFETY RULES EVERY TIME YOU USE THE TS OR THE RULES ARE USELESS.
2. Always use a splitter when possible
3. Stand to the side of the workpiece so if it does kick back it won’t hit you.
4. Always use a push stick and *DON’T GET YOUR FINGERS ANYWHERE NEAR A SPINNING BLADE, EVER!
5. I agree with Rance on the fence being parallel with the blade, but I leave the far end a little off (further away from the blade by a very small amount). This reduces the chance of kickback as the workpiece comes away from the saw blade at the end of the cut.
There are other rules, but for me the above are the main ones.
-- Mike, American in Norway
View Dez's profile
Dez
1097 posts in 2246 days
#5 posted 854 days ago
Never wear loose fitting sleeves/clothing. (applies to almost all equipment)
Don’t work when you are tired. (applies to almost all equipment and personal experience)
Never reach across the blade. (personal experience)
-- Folly ever comes cloaked in opportunity!
View knotscott's profile
knotscott
4189 posts in 1544 days
#6 posted 854 days ago
- Use the right blade for the job, and keep it sharp and clean.
- Feather boards and push sticks are your friends!
- Use a splitter or riving knife (the guard is a good idea too).
- Pieces that are flat and straight are easier to control.
- Keep the saw well tuned and aligned.
- Keep the table waxed.
- Think each cut through before cutting.
View helluvawreck's profile
helluvawreck
10413 posts in 1035 days
#7 posted 854 days ago
Probably the one I violate most often is never operate a table saw when you’re not concentrating on anything else but what you are doing with the saw. I’m always busy and always have a lot of things on my mind. This has been the way it is for 40 years. However, so far I’ve never had an accident that hurt me in any way. I realize that this rule should neverr be broken.
View Roger's profile
Roger
9191 posts in 973 days
#8 posted 854 days ago
always, always, unplug the power before touching/changing blades. “a good tuned saw is a safe saw” – me
View HorizontalMike's profile
HorizontalMike
4931 posts in 1083 days
#9 posted 854 days ago
Some may argue that this is not a safety tip, BUT how about using Bostik Dricote on your TS blade regularly. It made such a difference in cutting resistance that I almost couldn’t believe it, especially when I was ripping 8/4×9” x 10ft Ash using a 24-tooth Rip Freud blade. It’s not cheap but all I can say is WOW. Anything that minimizes the pushing effort on big lumber has my vote.
View NH_Hermit's profile
NH_Hermit
334 posts in 1265 days
#10 posted 854 days ago
Good question, Debbie.
and good responses. I really like Rance’s first rule. I’ll try to remember that one.
We can never be reminded too much to keep our wits about us.
-- John from Horse Shoe
View Kirk's profile
Kirk
95 posts in 2223 days
#11 posted 854 days ago
If you don’t know what your doing, don’t use it.
One thing has helped my Table Saw, the table surface is slick. That has meant more to me than anything except for dust collection. I had my table Blanchard ground, because it’s surface was rough to the point it was like sandpaper. Next to impossible to slide the wood across the table.
-- W. Kirk Crawford - Tularosa, New Mexico
View biglarry's profile
biglarry
63 posts in 857 days
#12 posted 854 days ago
As Ellen said “Never, EVER, lose your concentration!”
Working one evening doing a lot of repetitive cuts I was one the last cut and started to thing what the next step was and somehow put my left thumb in the blade. Luckily it only cut part way through but if you look at an x-ray you can see the blade kerf.
Also if you are doing a ton of ripping get a power feed. It can also be used when making moldings on a router table.
-- "When the going gets tough, switch to power tools." - Red Green
View cornflake's profile
cornflake
36 posts in 859 days
#13 posted 854 days ago
i have two:
1 always wear eye protection
2 never make push sticks out of plexiglass
View Chris 's profile
Chris
1850 posts in 2160 days
#14 posted 854 days ago
As someone that has suffered the amputation, and reattachment, of a digit I have to say ALWAYS err on the side of safety. Also, Until recently I have never really used an out feed table or support but have become convinced of their value as a safety device. It keeps me from reaching near or past the blade the blade. I just give the piece an extra little shove with the push stick and it slides onto the table.
-- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein
View canadianchips's profile
canadianchips
1773 posts in 1166 days
#15 posted 854 days ago
Have the floor area in front, side and back of table saw CLEAR.
Avoid tripping on something laying on the floor.
If it is a portable table saw, make sure it is sitting on SOLID table, avoid a rocking or tippy table saw, same goes for outfeed table.
Avoid stacking materials on side of table saw top as you are cutting. Very tempting, use another table to stack your work.
Avoid loose clothing while working on any power tool with spinning blades !
Never use your cast iron table top as a hammer pounding surface !
showing 1 through 15 of 45 replies
