walnut + maple end grain drink coasters finish?
Forum topic by Gary Fixler posted 01-18-2011 08:30 AM 4358 views 0 times favorited 7 replies Add to Favorites Watch
View Gary Fixler's profile
Gary Fixler
1001 posts in 3285 days
01-18-2011 08:30 AM
Topic tags/keywords: walnut maple coaster coasters finish question
I had some leftovers from a walnut and maple end grain cutting board, and realized I could make end grain coasters to match it. I have 4 little ~4”x4” striped square blocks, about 1/2” thick now. I’ll be finishing the cutting board with butcher block oil, which will significantly yellow the maple. I considered using it for the coasters as well, but I don’t think it’ll work. You’re not supposed to really soak end grain cutting boards, and coasters need to handle quite a bit of moisture. Any idea of a good finish that will allow someone to put a glass of ice water on it in the Florida heat? I’ve considered something like a cork appliqué on top, but it would hide the alternating wood stripes.
Thanks!
-- Gary, Los Angeles, video game animator
7 replies so far
View Dez's profile
Dez
1166 posts in 3981 days
#1 posted 01-18-2011 09:46 AM
You could use a drying oil like tung oil to get the color and then when dry a poly finish would make it pretty water resistant.
-- Folly ever comes cloaked in opportunity!
View Galirex's profile
Galirex
37 posts in 2891 days
#2 posted 01-19-2011 03:38 AM
How about fiberglass resin ? That would exclude moisture from ever permeating the wood, yet allow you to see through.
-- Don't complain about growing old, it's a priviledge denied many...
Gary Fixler
#3 posted 01-20-2011 04:39 AM
Thanks for the ideas. I hadn’t considered fiberglass resin, but I think it warrants some tests.
View travisowenfurniture's profile
travisowenfurniture
91 posts in 2594 days
#4 posted 01-20-2011 05:56 AM
I would go with Dez on this one, tung oil and poly, plus a coat of wax applied every few years for that extra amount of water deflection. The two part pour on finishes may work well for this, but I havn’t tried them so I can’t say for sure
-- http://www.facebook.com/travisowenfurniture
Gary Fixler
#5 posted 01-20-2011 01:11 PM
Thanks, Travis (and Dez!). I finished the board today and am shipping it off tomorrow to mom. I’m going to hang on to the coasters for a bit while I think about exactly what I’d like to do. They can be a surprise extra gift later. I’ll run some tests. I think I have tung oil, but I need to check.
View HokieMojo's profile
HokieMojo
2104 posts in 3631 days
#6 posted 02-10-2011 09:57 PM
i might be too late, but what about bar top finish? I don’t know a lot about it (or whether you can get smaller quantities) but I assume that it would be pretty water resistant.
View ellen35's profile
ellen35
2734 posts in 3336 days
#7 posted 02-10-2011 10:07 PM
I sprayed mine with spray on spar varnish. I used 4-5 coats and they are as good today as the day I sprayed them and we use them every day. I used Man-o-War spray on.
It was very easy to do and the finish looked like a poly finish.
