Forum topic by darnes | posted 08-24-2017 12:30 PM | 609 views | 0 times favorited | 14 replies | ![]() |
New to woodworking and have had a potential setback. I do all my work outside. Glue up went ok except it was 106 outside and the glue was dry practically as soon as it came out of the bottle. Setup fine and flat for the first 24 hours. Took it out but I think the heat caused it to cup once it was out in the sun for a bit. Then even though it was not in the forecast it rained cats and * dogs and blew the tarp off so the wood got a good wetting. I clamped it back down flat and leaving it to dry again. Any thing I have to worry about here? Not sure how much wet on unfinished wood you can get without causing a problem. I have kind of resigned myself to the idea that I may have to put an apron on it to maintain it being straight since the material has already cupped some and is not super thick to begin with. Also I have no idea what I am doing so take that in to consideration as well :) |
14 replies so far
#1 posted 08-24-2017 12:54 PM |
I guess oak would withstand ok a few years or rain. Nothing to worry about. |
#2 posted 08-24-2017 02:07 PM |
I wouldn’t worry about the wood but possibly the glue? |
#3 posted 08-24-2017 02:14 PM |
Depends on the type of glue. Titebond II or III would hold up though once. Welcome to Lumberjocks -- Mother Nature created it, I just assemble it. |
#4 posted 08-24-2017 02:15 PM |
something else you can do to help keep it flat is screw/glue some cleats onto the bottom. |
#5 posted 08-24-2017 02:27 PM |
You can screw if you make elongated holes in the cleat first. Don’t glue. That is just asking for trouble. -- No craft is very far from the line beyond which is magic. -- Lord Dunsany |
#6 posted 08-24-2017 03:38 PM |
You’ll be fixing a lot of stuff like this if you don’t move into a shop or at a minimum have some place to keep your materials equilibrized. -- Everything is a prototype thats why its one of a kind!! |
#7 posted 08-26-2017 01:40 AM |
I was using the Titebond III. I figured a tabletop would have spills so it wouldn’t hurt to have the waterproof.
#8 posted 08-26-2017 01:42 AM |
Why would glue be a problem and not sure I understand the elongated holes comment. Can you provide some more detial? You can screw if you make elongated holes in the cleat first. Don t glue. That is just asking for trouble. - JADobson
#9 posted 08-26-2017 01:50 AM |
Because wood has ‘seasonal movement’- it expands and contracts along its width significantly more that along its length as the moisture content changes with the seasons & weather. That is why breadboard ends are typically only glued and/or pinned solidly in the center, but all of the pins on the edges of the table go through an elongated slot in the tenon. Same would apply to a cleat on the bottom. -- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be" |
#10 posted 08-26-2017 03:32 AM |
ahhh Ok got ya :)
#11 posted 08-26-2017 11:08 AM |
The surface moisture from the rain will dry pretty quickly. I would find a flat level place inside your house and put down a row of stickers (1” x 1” wood spacers) every 12” apart on the floor, put the table top on the stickers, add another layer of stickers, and then add weight on top. Position a box fan to blow air over the top, and leave it like this for 4or 5 days, a week would be better. The space created by the stickers allows air to move over both sides of the table top (air on both sides is critically important), and the 12” spacing on the stickers provides very good support for the table top as the moisture picked up from the rain dries. -- Danny Located in Perry, GA. Forester. Wood-Mizer LT40HD35 Sawmill. Nyle L53 Dehumidification Kiln. hamsleyhardwood.com |
#12 posted 08-26-2017 01:31 PM |
Titebond recommends chilling your glue when working in hi temps. I used to be in McKinney, would put the bottle in the fridge an hour or so ahead of a glue up and got at least 5 minutes of open time. -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#13 posted 08-26-2017 02:10 PM |
Welcome to Ljs darnes Here are a couple links that may help http://workshopcompanion.com/KnowHow/Design/Nature_of_Wood/2_Wood_Movement/2_Wood_Movement.htm https://www.canadianwoodworking.com/tipstechniques/dealing-wood-movement -- https://www.artisticwoodstudio.com/videos wood crafting & woodworking classes |
#14 posted 08-26-2017 03:21 PM |
Dobson is very correct. Do not use a long piece to span the seams. Explanation below. Using TB3 and then getting rained on right away might be a concern. I think it takes about 2-4 weeks for the glue to cure to it’s waterproof state. After 40 years in the business of cabinet/furniture making, I got real stupid about 3 years ago, and glued a strip across the back side of a raised panel drawer front to have a solid place to attach to the drawer box. Within 6 weeks, the fronts (2 of them) popped off the drawers, and looked a lot like potato chips. I brought them back to the shop, and after agonizing for some time, I realized I could cut the strips. The first cut popped when almost through, and the front straightened about half way. A couple more cuts, and it was flat. Same thing on the other. Experience is; you can glue up seams you think might come apart, but it can not be a solid long strip covering the width of the project. -- Jerry (in Tucson) www.woodturnerstools.com |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
