worm screw
« back to Woodturning forum
Forum topic by Karda posted 08-23-2017 07:15 PM 572 views 0 times favorited 4 replies Add to Favorites Watch
View Karda's profile
Karda
1115 posts in 580 days
08-23-2017 07:15 PM
Hi, i am mounting a bowl blank on a worm screw but I can’t get thenscrew alined and it comes loose when I screw the blank on. I have a G3 chuck, the screw has a flat spot on the bottom, the part inside the jaws, but I can’t see a corrisponding flat on the chuck and the instruction are no help. What am I doing wrong. Thanks Mike
View LeeMills's profile
LeeMills
550 posts in 1328 days
#1 posted 08-23-2017 08:01 PM
The flats on the worm screw align with the jaw slides (not the jaws), The ends of the jaw slides are flat.
The easiest way to me is to have one jaw top side up (12:00), then turn the worm screw with a flat side up and insert.
Tighten the jaws almost all the way and pull the worm screw out and then fully tighten the jaws; this will insure the screw is fully extended and can not come out any further during use.
Karda
#2 posted 08-23-2017 08:11 PM
ok thanks
LeeMills
#3 posted 08-23-2017 11:10 PM
I figured someone would have a video … and shur ‘nuff
Only about six minutes long and may be other tips you can use.
https://www.youtube.com/watch?v=EI-utYAfXJI
Karda
#4 posted 08-23-2017 11:22 PM
thanks for the video It answered a lot of questions
