My Router died
Forum topic by Dee1 posted 08-23-2017 06:15 PM 730 views 0 times favorited 13 replies Add to Favorites Watch
View Dee1's profile
Dee1
306 posts in 2127 days
08-23-2017 06:15 PM
Ok I have an old Bosh 10 amp Router mounted in my table that I have used for years well today it died and I am looking to replace it
I never use it off the table but that said I would like one that is a little easier to set a close depth than this old Bosh
Any and all thoughts would be appreciated
I do mostly small projects.
Dee1
13 replies so far
View gargey's profile
gargey
1013 posts in 1014 days
#1 posted 08-23-2017 06:43 PM
A peanut is neither a pea, nor a nut.
View Loren's profile
10477 posts in 3886 days
#2 posted 08-23-2017 06:44 PM
Even though I burned one up I really like
the Milwaukee “bodygrip” router. Everything
about it is designed well and depth can be
adjusted from the top using a hex extension
wrench. It isn’t the most whiz-bang design
for table use (for that look at the Triton routers)
but it gets the job done.
I don’t have one but these days you can get
router lifts that hold fixed-base router motors.
Such lifts cancel-out some of the inherent
limitations of inexpensive basic routers like
the Porter Cable 690, a reliable router that
can be bought on ebay for less than $100.
View Gene Howe's profile
Gene Howe
11152 posts in 3667 days
#3 posted 08-23-2017 06:48 PM
May it rest in peace.
I’d look seriously at Triton.
View RKRKAR's profile
RKRKAR
2 posts in 546 days
#4 posted 08-23-2017 07:03 PM
I have that same Milwaukee router mounted in a Jess-Em router lift on my self built Router cabinet. It is VERY precise and I have been known to lift the whole thing out, plate & all for use as a trim router. I love the Jess-em and the Milwaukee as well & know you will like this Milwaukee Jess-Em combo also! . I just purchased a Bosch 1617 EVSPK plunge router for doing mortices & inlay work.
-- Robby
View rwe2156's profile
rwe2156
3230 posts in 1719 days
#5 posted 08-23-2017 07:31 PM
If you want a beefy router: Triton. I recently bought one and love it. I don’t use a router lift the built in one works fine enough for me. Yes, you have to lock and unlock, but to me and for what I do, that’s not worth spending several hundred on a lift.
If you’re doing light stuff (no raised panels, etc) a 2HP router will do. I own all PC’s but I like the DeWalt
View knotscott's profile (online now)
knotscott
8178 posts in 3614 days
#6 posted 08-23-2017 08:18 PM
I really like both my Milwaukee routers too. 5615 for smaller stuff and 5625 for hogging raised panels. The 5616 is pretty similar to the 5615 but gives you variable speed control.
View WhyMe's profile
WhyMe
1080 posts in 1799 days
#7 posted 08-23-2017 09:10 PM
I currently use a Bosch 1617EVS in a table and the 1617 depth can be adjusted from the table top. You do have to reach under the table to lock and unlock. I’ve been pleased with it, lots of hours on it with no issues.
View Rich's profile
Rich
4002 posts in 827 days
#8 posted 08-23-2017 10:12 PM
- gargey
And you called me obtuse :)
View LittleBlackDuck's profile
LittleBlackDuck
2120 posts in 1059 days
#9 posted 08-24-2017 12:35 AM
- Dee1
Dee1, you have opened up a can of worms… That’s like asking people for a picture of their grandkids… everyone will show a different picture (I hope)...
You didn’t specify a price limit.
Just remember you can always do your mostly small project on a beefy router, however, am underpowered router would object if you ever decide to feed it that “odd large project”.
My first serious router was a Triton (back in the days before plastic parts) and still not missing a beat. However my current go to router (when talking tabletop mode) is a Porta Cable 7518 on a Woodpecker PRL-V2 lifter (can’t be beaten for ease of use/versatility – the lifter).
If you are not budget constrained… you cannot go past a Festool… and drive it to your worksite in your Rolls-Royce! Problem is, it’s features would be wasted in a table top.
For a small router/trimmer… I highly recommend a Bocsh Palm Trimmer GMR1. It has a unique knurled screw for a sneaky “depth-of-cut” fine adjustment.
View Dee1's profile
Dee1
#10 posted 08-24-2017 09:36 PM
Ok I listened to all you nice guys and ordered a Triton the smaller of the two and now anxiously waiting for it.
I came very close to buying another Bosch but then I said lets see what these guys are talking about and ordered the Triton
View Kirk650's profile
Kirk650
585 posts in 986 days
#11 posted 08-24-2017 09:46 PM
I have a Milwaukee body grip router, a couple of Bosch 1617evs, and a PC (690 family, but I forget the number). Any of them will do, and can be raised and lowered from above. The PC is in the router table and has been used for years. I can’t really say one of those routers is the best, but I can say that the Milwaukee is one solid precise high quality router.
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#12 posted 08-24-2017 10:35 PM
- Dee1
Just curious… how did it ‘die’? Most likely, a new set of bearings and/or brushes and it will be back to running like new for just a few bucks :) Those things are pretty hard to kill, even if you just run them ragged without regard to maintenance.
View Dee1's profile
Dee1
#13 posted 08-25-2017 12:51 AM
Ok how did it die, well it slowed down, doing some very light rounding over . using a 1/8 Round over bit. then it shot a whole bunch of flames out the bottom, very spectacular. Now I have had this router in at least three tables and really do not remember when I got it? on the plate it says Bosh 1604 and after a bunch of unreadable there is a date of 1984? I just figured it was past replacement time?
Now if it is fixable I will have two!
Thanks guys
Dee1
