moister content
Forum topic by CaptCoan posted 08-22-2017 01:05 AM 633 views 0 times favorited 18 replies Add to Favorites Watch
View CaptCoan's profile
CaptCoan
24 posts in 1909 days
08-22-2017 01:05 AM
I’m going to air dry some Cherry from a tree in our yard (2’ thick) at what moister content is acceptable to work the wood. I know it usually take a year per inch
-- EVERY MAN MAKES HIS OWN WORLD/ THE WORLD IS A BEAUTIFUL PLACE
18 replies so far
View papadan's profile
papadan
3584 posts in 3271 days
#1 posted 08-22-2017 01:10 AM
You want the moisture to be at 12% or less. You could go ahead and cut that into lumber and just stack and sticker to save a lot of drying time for 2’ thick wood.
View Loren's profile
9935 posts in 3551 days
#2 posted 08-22-2017 01:12 AM
For furniture making about 7%.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2212 days
#3 posted 08-22-2017 06:16 AM
- Loren
How do you get 7% unless you live someplace like Arizona? I have wood in my shop and in my house that been there for years and years and it’s never going to be 7%. If I took that wood and kiln dry it to 7% and put it back in my house and shop it would be back to 10-12 % in a few month after equalizing to it environment. There no place in Alaska I could even buy wood that is 7%.
View Tony_S's profile
Tony_S
817 posts in 2986 days
#4 posted 08-22-2017 10:21 AM
Take this for what it’s worth as I have very little experience with air dried lumber.
Given that you’re in Louisiana, and I’m assuming that you’re drying it outdoors, I’d be surprised if you get it much drier than 12ish. Best bet IMO is shoot for that # and then bring it indoors and let it stabilize for at least a month. I would suspect it will drop another couple of points, but not much more given the high humidity.
AG
I just measured 500 bdft of K.D 8/4 QSWO that came in yesterday. Safe bet it came from mid west usa….it ranged anywhere from 6.2 to 8.2. It will typically settle out at 7.5-8.5 in this climate…a lot depends on summer/winter humidity swings. They can be pretty drastic some years.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View WDHLT15's profile
WDHLT15
1720 posts in 2379 days
#5 posted 08-22-2017 11:48 AM
I like less than 10% in Georgia. Cannot get it that low just by air drying. I agree with Tony. Air dry it then bring it inside ahead of the time that you need it and let it dry further in a heated and cooled space.
I did an experiment on some 7/8” thick red oak (skip planed) that I had air dried to 13.5%. Brought it inside the house and stickered it in an out of the way place. Measured the moisture content every couple of days and wrote that on the top boards. Beginning in March, the wood went from 13.5% to 9.5% in 5 weeks. It stayed at 9.5% all summer until September, then I finish planed it to 3/4”, v-grooved it, and put it up as wainscott paneling.
View Wildwood's profile
Wildwood
2240 posts in 2038 days
#6 posted 08-22-2017 12:17 PM
If go to this link and check out fig 13-1, and table 13-2 should get you in the ball park. Have to scroll dow some pages to find info!
https://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr190/chapter_13.pdf
Figure 13–1. Recommended average moisture con­tent for interior use of wood products in various areas of the United States.
Table 13–2. Recommended moisture content values for various wood products at time of installation
That old 1” per foot per year only good for some types of pine but not all and no bearing on hard woods.
-- Bill
WDHLT15
#7 posted 08-23-2017 11:58 AM
The 1 year per inch of thickness rule of thumb is a poor one. But it is now an Internet Legend.
View ArtMann's profile
ArtMann
824 posts in 719 days
#8 posted 08-23-2017 02:58 PM
If a 6 or 7 percent moisture content is essential, then how in the world did colonial woodworkers create that exquisite furniture on display in the historic town of Williamsburg, Virginia? Much of that furniture has been around for several centuries and hasn’t come apart yet.
Wildwood
#9 posted 08-23-2017 07:49 PM
Think those two charts from Wood Handbook gives you ball park moisture contents for part of the country where you live that will help. Of course don’t take into account current weather conditions or relative humidity in area where you live so have to make some adjustments that.
This time of year sap running, moisture content of a freshly felled tree can exceed 100% MC so most consumer grade moisture meters useless. Two inch thick Cherry boards & moisture meter discussion not something want to get into.
End sealing, stacking & stickering, storing out of the weather off the ground for several months with just air circulation should get you where need to be.
-- Bill
Tony_S
#10 posted 08-23-2017 10:53 PM
It isn’t essential, It’s just a general rule of thumb. The moisture content the wood settles at is determined by the average relative/ambient humidity in the general region.
Much of that furniture has been around for several centuries and hasn t come apart yet.
- ArtMann
Bring that same stable exquisite furniture here and the tops will more than likely crack and joints loosen, as it’s considerably drier here(Calgary), particularly in the winter than it is in the southern US. That’s why we have a shitty antique market here.
All due to largely different relative/ambient humidity.
View jimintx's profile
jimintx
628 posts in 1487 days
#11 posted 08-23-2017 11:02 PM
At my house in Houston, we run the AC runs on cool 24 hours a day for ~10 months of the year, and the heat about two, maybe three weeks out of the other two months (see note).
We have a few moisture measuring instruments around here. If we see inside humidity of less than 55-60%, we think it is wonderful.
I cannot imagine how I could get wood moisture down to <15 percent on any regular basis. Seriously?! How could I do that short of a drying kiln of some sort? What am I missing here about the moisture content of wood, and the comments about the ambient humidity?
(Note: My shop is a separate structure, but runs with almost exactly the same schedule.)
-- Jim, Houston, TX
View Rich's profile (online now)
Rich
2267 posts in 492 days
#12 posted 08-23-2017 11:10 PM
If a 6 or 7 percent moisture content is essential, then how in the world did colonial woodworkers create that exquisite furniture on display in the historic town of Williamsburg, Virginia? Much of that furniture has been around for several centuries and hasn t come apart yet.
- ArtMann
That furniture would have all been built from old growth lumber with dense, tight rings. I wonder how much difference there is compared to today’s wood in terms of stability in varying levels of humidity. Those guys had 24” wide slabs to work with.
-- No matter how much you push the envelope, it'll still be stationery.
Tony_S
#13 posted 08-23-2017 11:52 PM
I cannot imagine how I could get wood moisture down to <15>
This explains it better than I can
https://www.wagnermeters.com/what-is-equilibrium-moisture-content/
Rich
#14 posted 08-24-2017 12:47 AM
- Tony_S
Really good article. Thanks for sharing.
View DirtyMike's profile
DirtyMike
637 posts in 805 days
#15 posted 08-24-2017 12:55 AM
- WDHLT15
yes it is, so is the idea that 7% is ideal for furniture.
