Light Walnut Finish?
Forum topic by Andy posted 08-21-2017 06:19 PM 632 views 0 times favorited 11 replies Add to Favorites Watch
View Andy's profile
Andy
11 posts in 514 days
08-21-2017 06:19 PM
Topic tags/keywords: walnut question modern finishing
Hi Guys,
I’m working on a desk that is primarily made out of walnut, and i’m looking for a way to finish it that will only darken it minimally. I tried applying Watco danish oil to a test piece, and it darkened the wood too much for my taste.
I found this piece online which depicts what i’m after.
Any tips on how to achieve something like that?
My go-to favorite finish in the past (this one) leaves the wood with an ideal matte look, but doesn’t darken the wood at all and is also water based, making it unsuitable for any oil based finishes.
Any tips are appreciated!
11 replies so far
View ChefHDAN's profile
ChefHDAN
1227 posts in 3085 days
#1 posted 08-21-2017 06:26 PM
have you tried Arm R Seal?
View rodneywt1180b's profile
rodneywt1180b
179 posts in 622 days
#2 posted 08-21-2017 06:41 PM
Have you tried just a clear finish? If that’s too light then I would look at a dilute coat of water based aniline dye stain instead. You can add more coats to darken it to the effect you want.
Rodney
-- Rodney, Centralia, WA, USA www.etsy.com/shop/ASturdyStick
5233 posts in 2729 days
#3 posted 08-21-2017 06:48 PM
I’m thinking that any oil based finish will do pretty much the same thing the Watco did. But the pic of what you want actually looks to me like you want to lighten the natural color of the walnut…and I’m not sure that’s easily possible.
View Andy's profile
Andy
#4 posted 08-21-2017 06:55 PM
- ChefHDAN
I haven’t. I did see people recommending it before when I was looking for a matte finish for another project, but I ended up going with the Dead Flat Varnish linked in my first post. I’ll look around for some examples of Arm R Seal used on walnut.
Thanks!
View Andy's profile
Andy
#5 posted 08-21-2017 06:58 PM
I m thinking that any oil based finish will do pretty much the same thing the Watco did. But the pic of what you want actually looks to me like you want to lighten the natural color of the walnut…and I m not sure that s easily possible.
- Fred Hargis
My unfinished piece is actually just slightly lighter than the image in my original post. It’s almost like my unfinished walnut just has a slight haze over it that I want to darken, then seal.
I’ll look into the aniline dye that Rodney recommended.
View ClammyBallz's profile
ClammyBallz
449 posts in 1372 days
#6 posted 08-21-2017 07:03 PM
I would try a platina or blonde shellac followed by a water based poly.
rodneywt1180b
#7 posted 08-21-2017 09:21 PM
I didn’t think of shellac. Good idea. It might be just enough for the effect you’re after.
View Ron Aylor's profile
Ron Aylor
2649 posts in 883 days
#8 posted 08-21-2017 10:18 PM
Perhaps you should consider using butternut instead of walnut for the project.
View Andy's profile
Andy
#9 posted 08-21-2017 10:24 PM
- Ron Aylor
Thanks Ron, i’ll definitely consider that next time. Right now the desk is pretty much done though.
My plan right now, based on advice here and a bit of Googling, is to try the light shellac that Clammy recommended, followed by the water based poly that I already have on hand. Possibly with a bit of sanding after the shellac coat. Going to pick up some shellac on my way home tonight and give it a try on a tester.
I’ll try to remember to share my results here.
View DS's profile
DS
3044 posts in 2656 days
#10 posted 08-21-2017 10:48 PM
To my eye it appears to have a white wash pickling stain on the walnut.
View gargey's profile
gargey
1013 posts in 1011 days
#11 posted 08-21-2017 11:06 PM
Yeah its like you’re going for a sapwood look, an unusual approach.
