Extra Wide finger joints?
Forum topic by Dez posted 01-17-2011 12:16 AM 5426 views 0 times favorited 8 replies Add to Favorites Watch
View Dez's profile
1166 posts in 4013 days
01-17-2011 12:16 AM
Topic tags/keywords: tablesaw
A friend of mine wants to make some boxes for his beehives.
Because they are quite large he would like to make the fingers 1 1/2” wide or more so that it doesn’t take forever and a day. (he needs to make quite a few boxes)
I have never made or used finger joints!
Anyone have some advice, tips, technique, or links to share?
I have many links and plans for building finger joint jigs but nothing about that wide of a finger!
He has a dado set for his TS that he can use.
-- Folly ever comes cloaked in opportunity!
8 replies so far
View bigike's profile
4050 posts in 3224 days
#1 posted 01-17-2011 12:29 AM
I would draw it out on the wood and then cut the joints, it’s tough cuz there is no blade that can make that kind of cut in one pass.
-- Ike, Big Daddies Woodshop,
View oluf's profile
260 posts in 2975 days
#2 posted 01-17-2011 12:32 AM
Are you talking about finger joints or box jointery?. Finger joints are most generly used to join stock togather end to end and is a millwork funtion. Box joints are interlocking fingers for making neat and strong corner joints. If the box will be made of 3/4 ” stock, using a lock miter bit with a router might be faster and stronger.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
View Dez's profile
#3 posted 01-17-2011 01:05 AM
Duh! My stupid! Box joint is what I meant. (Bad headache today)
No router. Box materials are 3/4” thick. The joints do not have to be super precise, just close enough to fit.
I was thinking that he could use the dado blade set to max width and a fixed indexing pin to match and a loose indexing pin 1 1/2” wide and make multiple passes????
View shipwright's profile
7940 posts in 2734 days
#4 posted 01-17-2011 01:45 AM
-- Paul M ..............If God wanted us to have fiberglass boats he would have given us fibreglass trees.
18227 posts in 3612 days
#5 posted 01-17-2011 07:43 AM
The bee boxes I remember on the farm had wide box joints like you are talking about. I would set up a jig and dado and do what you are saying.
View studie's profile
618 posts in 3082 days
#6 posted 01-17-2011 08:11 AM
Festool Domino! After you glue and clamp butt joints square and true just use the Domino to have an exposed loose tenon join of the box. I think your way sounds like more fun tho. Even then the box joint would probably be even a stronger joint, hey what about a biscuit joiner?
-- $tudie
View Dez's profile
#7 posted 01-17-2011 09:37 AM
Thanks everyone!
The tools he has are the ones he will have to use!
I will go over and help him build a box joint jig and figure out how to make the extra wide joints. I thought about biscuit joiner too – but mine is in storage!
View woody57's profile
650 posts in 3363 days
#8 posted 01-17-2011 10:21 PM
It’s probably going to be faster to use the dado blade in the table saw set at 3/4” and make them all 3/4” wide. You would be making the same number of passes as you would for 1 1/2” and it would be more accurate. There’s a lot of good information about box joint jigs on LJ’s.
-- Emmett, from Georgia
