theorizing brainstorm time
Forum topic by willhime posted 08-21-2017 03:37 AM 1428 views 0 times favorited 5 replies Add to Favorites Watch
View willhime's profile
willhime
108 posts in 1566 days
08-21-2017 03:37 AM
Topic tags/keywords: question trick tip jig resource carving tool chisel router blade sander carving finishing joining sanding
I randomly ran across this picture and stared at it for 20 minutes. I have no idea how this was accomplished and wanted to see if there’s any theories. I’ve been making furniture professionally for 3 years and don’t have an answer. The closest I can come up with is that they planed the live edge stuff to square on the bottom where it’s inlayed, but the surface line is still uneven and inset perfectly. The edge lines are flawless and the bark is still retained on the legs. I’m at a loss
-- Burn your fire for no witness
5 replies so far
View Loren's profile
10476 posts in 3675 days
#1 posted 08-21-2017 04:10 AM
Well, for one, that box will explode if it
isn’t veneered, so all the surrounding wood
is presumably veneer. Inlaying the branches
into the substrate was surely skilled work,
but I suppose bondo could have easily been
used to compensate for irregularities in the
branches.
View ColonelTravis's profile
ColonelTravis
1804 posts in 1921 days
#2 posted 08-21-2017 04:18 AM
Was looking at their site and what intrigued me more was a entire sink and counter top made of wood. Never seen that before. Would not buy one.
Regarding the groove for the branches, just seems like very careful outlining and carving. If there were gaps, they could be filled in with any number of things.
View Gilley23's profile
Gilley23
489 posts in 409 days
#3 posted 08-21-2017 04:38 AM
What site is that?
willhime
#4 posted 08-21-2017 06:18 AM
View Tony_S's profile
Tony_S
871 posts in 3110 days
#5 posted 08-21-2017 09:24 AM
isn t veneered, so all the surrounding wood
branches.
- Loren
Yep….the box is definitely veneered, and I would suspect that the face surface of the branches are as well.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
