Using a Router
Forum topic by Redford1947 posted 01-16-2011 07:06 PM 996 views 0 times favorited 5 replies Add to Favorites Watch
View Redford1947's profile
Redford1947
35 posts in 2928 days
01-16-2011 07:06 PM
A little new to routers and am stuck on something. I am using 3/4” (full) maghony wood. I am trying to cut a rabbit on one side to fit the other piece into. Every bit I see only goes to 1/2”. How do I cut a rabbit so the full 3/4 will fit into?
Thanks for the response to my other post. Lots of good input out there.
Redman
5 replies so far
View spamfilterman's profile
spamfilterman
149 posts in 3140 days
#1 posted 01-16-2011 07:21 PM
Like GarageWoodworks said, try a straight bit instead of a rabbeting bit.
You can then make multiple passes on the router table, or with a straight-edge guide w/o a router table.
View Loren's profile
10477 posts in 3766 days
#2 posted 01-16-2011 07:57 PM
You can also rabbet both pieces to 3/8” and fit them together
that way.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4243 days
#3 posted 01-17-2011 12:34 AM
Just to open up your options further: Use a ¾ top-bearing bit following a board clamped ¾” from the bottom of the board you want the rabbet on.
Dan Lyke
#4 posted 01-17-2011 12:34 AM
View EEngineer's profile
EEngineer
1113 posts in 3731 days
#5 posted 01-17-2011 01:24 AM
Yeah, lotsa BS here!
Look, you got a 1/2” bit and a 3/4” dado you want to cut… 1st, you cut the dado to 1/2 ” then, you move the fence 1/4” and make another pass. On a router table or a table saw or just using a guide to cut, it is all the same.
This is further complicated by the fact that almost nothing anymore is a true 1/2”, 3/4” whatever… everyone is shaving a few thousandth off of the finished goods. To make a tight fit, don’t use a 3/4” dado bit and cut it, use a 1/2” bit and trim it to fit what the width is. Fine, get yourself a 3/4” bit and find that the finished thickness is looser than…. but I digress.
What the hell is woodworking, if not to make our adjustments to this kind of variance? If you cannot handle this, then you cannot handle woodworking in general.
