| Forum topic by Don | posted 858 days ago | 4089 views | 1 time favorited | 139 replies | ![]() |
858 days ago |
Topic tags/keywords: question I’ve hated the american system of measurement ever since I learned the metric system in junior high school some 30 years ago when I was told that the US had plans to officially convert to Metric. That obviously never happened. The current project I’m working on has dimensions down to an accuracy of 1/64 of an inch making it particularly easy to screw things up. I swear the number one cause for mistakes in my shop is misscalulations due to the stupidity of a system based on fractions. It would be so much easier if it were in Metric. The only reason I don’t just use it myself is because then I would have to use both systems and be converting all the time since materials and nearly everything else I ever buy for the shop is in american and I’d probobly make even more mistakes as a result. I’m mostly just venting here but I’m curious if anyone else is just as frustrated as I am with this completly stupid measurement system? Or know any tricks to making it easier to deal with (besides a calulator which I use but really doesn’t help that much)? -- Don - I wood work if I could. Redmond WA. |
139 replies so far
#1 posted 858 days ago |
We did convert to metric. ALMOST. Now we get to deal with metric and Imperial measurments. Then when I drive acrooss the St. Claire river I can buy fuel in US gallons. -- "My mission in life - make everyone smile !" |
#2 posted 858 days ago |
I use Fastcap tape measures that have both scales on it. -- I don't make mistakes, only design changes....www.dgmwoodworks.com |
#3 posted 858 days ago |
I wonder if anyone makes a decimal imperial ruler or measuring tape? It seems this would address your not wanting to work in both SI and imperial and resolve the fractions issue…I know you can get decimal inch digital calipers. -- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2 |
#4 posted 858 days ago |
The Starrett Digitape converts imperial to metric and vise versa. It also In guitar making I’ve learned to think in metric in small increments and It may seem ridiculous, but I basically think in three systems when I do |
#5 posted 858 days ago |
Problem is that have have talked to other woodworkers from other countries who ask the exact question as use, only in reverse. I don’t think it is an issue of which system is used. I think it boils down to an issue of not having a universal system worldwide when some of us get plans from sources all over the world. I just had a bear of a time with measurement conversion on the flip flop of what you have had problems with. I had plans with metric measurement, all the way down to the 2mm and 4mm slots in parts that had to go inside of each other. Well, it throws you a curve ball when you cut those patterns with 4mm slots and 1/4” plywood (or 1/8” if I’d been able to even get that) has to go into that slot. |
#6 posted 858 days ago |
I’m a Canadian, and was born late enough last century to have grown up using the metric system. However, I use the Imperial system for all my woodworking. For rough measurements, I find the imperial system a lot easier. It is simpler to look at a tape measure and see the fractions, rather than to have to count out the millimeters. I can see 7/8” a lot quicker than squinting to see if something is 7mm or 8mm. I agree though, for accuracy, the metric system is superior, really, anything less than 1/8” I start having to scratch my head. When I measure stuff with my digital caliper, I often get strange fractions eg. 17/64 which is really frustrating because I can’t quickly “see” the measurement in my head. -- Rob, Sault Ste. Marie, Ontario |
#7 posted 858 days ago |
The other thing I want to add is a big “amen” after reading William’s post. Well put. Sure gets tiring having to have 2 sets of wrenches, allen keys, sockets etc. -- Rob, Sault Ste. Marie, Ontario |
#8 posted 858 days ago |
I have been around scientific types all my life, so both systems of measurement are pretty natural to me. I tend to convert fractional sizes to decimal in my head, now converting those SAE decimals to metric is a bit more calculation intensive, but not a big deal… I know that most manufacturing industries that are still in the U.S. have for the most part converted. Now I have had to deal with both U.S. manufactured machines, as well as foreign manufactured machines that have had fasteners and threads in both systems of measurement… I think due to the history, and the LARGE amounts of existing structures and systems, things like dimensional lumber, and plumbing fittings are going to be the inch system for years to come… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#9 posted 858 days ago |
Wow, don’t get me started. lol -- Roger-R, Republic of Texas. "Always look on the Bright Side of Life" - An eyeball to eyeball confrontation with a blind person is as complete waste of Time. |
#10 posted 858 days ago |
Well said Rob, those are exactly my headaches. I know how big 7/8 or 1/4 is but I need a calulator to figure out that 17/64 is just a hair over 1/4. But a number like 0.26 is really easy to tell that it’s a hair over .25. And having to own 2 sets of tools and then trying to figure out which set I need depending on which machine I’m trying to work on drives me up a fricken wall… -- Don - I wood work if I could. Redmond WA. |
#11 posted 858 days ago |
As for the “two sets of tools” problem, you are a lucky dog if all you have to do is figure out which set to use on which machine. I done mechanic work for thirteen years. On cars and truck from american companies made after about the mid-eighties, it was easy to tell which set your needed to work on them, BOTH! |
#12 posted 858 days ago |
William; I’ve done a lot of work on cars as well, and the lack of standardization in the auto industry, or as you put it even in one car is frustrating. I’ve rounded my share of bolt heads using metric because the other bolts were metric, except in one… Torx…another excuse to have to buy another set of sockets, and screwdrivers. -- Rob, Sault Ste. Marie, Ontario |
#13 posted 857 days ago |
Listening to all those mechanical stories ! Now I understand why the mechanics used to scream when I drove my VW beetle into the shop back in the 70’s. He sold me the used car, threw in a set of open end Metric wrenches and metric sockets. -- "My mission in life - make everyone smile !" |
#14 posted 857 days ago |
ahh conservative americans, don’t like change hehe. guess you could compare it to when we switched to the euro 9 years ago, givng up your own currency and it’s history is not easy. you need to learn the value of money again, but now that we adapted life is so much more easy. especially for me because half my customers are dutch. |
#15 posted 857 days ago |
I don’t care if it’s metric or imperial, I just wish we were working with one system worldwide. Since the metric system appears to be the future for the US and it is well established in the rest of the world – let’s get there faster. I have 2 complete sets of wrenches and 2 sets of drill bits. I recently had to get an adaptor to handle router bits with an 8 mm shaft. I thought the post supporting the tool rest on my lathe was 1” in diameter and I ordered a new one. Only after I got it did I realize that the post is 25 mm. You cannot put a 1” post in a 25 mm hole. Compared to most other industries, I think carpentry and woodworking are two of the slowest to make the transition. -- Rich, Cedar Rapids, IA - I'm a woodworker. I don't create beauty, I reveal it. |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15785 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
