Compressor safety valve keeps popping
Forum topic by Grantman posted 08-19-2017 04:26 PM 793 views 0 times favorited 10 replies Add to Favorites Watch
View Grantman's profile
Grantman
113 posts in 4048 days
08-19-2017 04:26 PM
Topic tags/keywords: compressor porter cable
I have a five year old Porter Cable pancake compressor, the red bellied 2002 model that I got from the Depot.
About a month ago the safety valve started popping at about 180 psi. My workaround was to charge it to 150, do what I had to do, and finish my work.
A little online research told me the valve was easily replaceable so this morning I did so.
Firing it up it happened again. Brand new safety valve and actually I replaced the drain valve too as long as I was at it.
Looking for any insight as to why the safety valve would pop at only 180 psi. The regulator is set for about 95 psi, by the way.
Thanks in advance.
10 replies so far
View MrUnix's profile
MrUnix
6757 posts in 2221 days
#1 posted 08-19-2017 07:16 PM
What model is the compressor? The C2002 is only rated for up to 150psi. I don’t think I’ve ever seen one of those little compressors that was designed for much more than 150psi… the current ones listed on their site are all 135-150 with only one as high as 165psi. Sounds like you have a problem other than the safety valve (which seems to be working correctly!).
View Andybb's profile
Andybb
1012 posts in 625 days
#2 posted 08-19-2017 07:28 PM
+1 Brad
180psi from a pancake (or any small compressor) is awfully high IMO. Sounds like the valve is working and preventing a catastrophe.
What do you mean the reg is set for 95psi? How is it getting to 180 if set for 95? What am I missing? The output is set for 95 but it is charging the tank past 180?
-- Andy - Seattle USA
View SignWave's profile
SignWave
440 posts in 3057 days
#3 posted 08-19-2017 08:12 PM
It sounds like the pressure switch is not shutting off at the max pressure. I agree that the safety valve probably prevented a serious accident. I would not operate this compressor until you change the pressure switch and make sure the new one is shutting of the motor at the proper max pressure.
-- Barry, http://BarrysWorkshop.com/
Grantman
#4 posted 08-20-2017 02:05 AM
Thanks to all. I don’t know anything about a pressure switch but I’ll research it. In the past I’ve simply turned it on and it shut off automatically and I never looked at the actual readings.
Re:95 on the regulator, it’s my understanding that that’s the pressure at which the the air goes out, not what’s in the tank.
Appreciate the feedback. New pressure switch here we come, I guess.
View cutmantom's profile
cutmantom
405 posts in 3057 days
#5 posted 08-20-2017 02:12 AM
The switch may be able to be adjusted
View Gilley23's profile
Gilley23
489 posts in 404 days
#6 posted 08-20-2017 11:07 AM
It sounds like you’ve outgrown your little compressor and need one with a larger air tank. Your safety valve works and is working, you don’t need a new one. The issue is that you’re trying to push your little pancake compressor further than it’s meant to go.
View Kazooman's profile (online now)
Kazooman
1024 posts in 1974 days
#7 posted 08-20-2017 01:12 PM
It sounds like you ve outgrown your little compressor and need one with a larger air tank. Your safety valve works and is working, you don t need a new one. The issue is that you re trying to push your little pancake compressor further than it s meant to go.
- Gilley23
The safety valve releasing has nothing to do with pushing his compressor further than it is meant to go. The OP didn’t even mention what he was using the compressor for. Starting it up for a single shot with a pin nailer would result in the pressure relief opening. Sine Wave seems to have it right, the pressure switch is not shutting the compressor off when it reaches the set point and it keeps running until the pressure relief kicks in.
View splintergroup's profile
splintergroup
2069 posts in 1244 days
#8 posted 08-20-2017 02:14 PM
The 95psi is the air pressure in the line, not the tank. Give the pressure switch a good blow out with compressed air, may be saw dust plugging up the works.
SignWave
#9 posted 08-20-2017 03:09 PM
Thanks to all. I don t know anything about a pressure switch but I ll research it. In the past I ve simply turned it on and it shut off automatically and I never looked at the actual readings.
- Grantman
I think this covers replacement for your compressor
https://www.youtube.com/watch?v=XC5knqVm66k
Grantman
#10 posted 08-20-2017 09:59 PM
Thanks again for the last couple of replies. I watched the video and looks pretty straight forward. I guess to blow it out with compressed air means getting a can ‘cuz if it’s taken apart, ain’t much I can do with it at that point!
Cheers to all.
