Frame and panel
Forum topic by Maximillian posted 01-15-2011 09:35 PM 1040 views 0 times favorited 4 replies Add to Favorites Watch
View Maximillian's profile
Maximillian
84 posts in 3306 days
01-15-2011 09:35 PM
Hi guys
Long time no hear from me. My wood working has been on hold while I have been doing serious reconstruction work on my house; I am turning half of it into Farmstay accommodation. So, the workshop became a store room for a year.
I am now turning to making some frame and panel wardrobe doors, using 3 mm bamboo ply (woven) for the panel. I have grooved the frame to accept the panel However, because the ply is not a consistent 3mm thick the groove in the frame has to be about 4.5 mm. This causes the ply to flap around a little in some places. Any tips on how to secure the ply? Should I glue it, “wedge” it?
Cheers
Max
-- Max, New Zealand
View childress's profile
childress
841 posts in 3567 days
#1 posted 01-15-2011 11:11 PM
How about….. Space balls. And no, they’re not related to the movie :)
-- Childress Woodworks
View lilredweldingrod's profile
lilredweldingrod
2496 posts in 3132 days
#2 posted 01-16-2011 04:53 AM
I take was paper and run several stringers of silicon, let it set up and cut the stringers in to 12-19mm lengths and place what I need to stop the rattle. Same as the space balls , just cheaper.
View Colin 's profile
Colin
93 posts in 2836 days
#3 posted 01-16-2011 07:43 AM
I use screen spline (either of the other suggestions will work too) then put some clear adhesive caulk in the groove. Enough so that it will just about squeeze out when you put the panel in. If you do have squeeze out in some areas, it is not that difficult to clean up.
-- http://www.columbiawoodscreendoors.com
Maximillian
#4 posted 01-16-2011 10:18 PM
Thanks Guys
All good suggestions. I especially like LilRed’s idea as it allows me to make packers of varying widths
-- Max, New Zealand
