cabinet painting: removing and then reusing hinge screw holes
Forum topic by one60fourth posted 08-18-2017 11:20 PM 1233 views 0 times favorited 10 replies Add to Favorites Watch
View one60fourth's profile
one60fourth
31 posts in 1461 days
08-18-2017 11:20 PM
I have newly built bathroom cabinets and am about to paint the doors. The euro hinges have already been installed. (I installed hinges before painting so I could properly fit the inset flush with the face frame doors.) The doors are made of poplar. Is it OK to remove the hinges—held in place with a 35mm hole and two screws through a base plate—and then rescrew the them into the same holes after painting? I tried it on a practice piece of poplar and it seems to snug up OK the second time but I would feel more comfortable with a second opinion on the strength of a reused hole. The screws are 1/2” screws with coarse threads. Maybe I should dip them in some kind of glue prior to rescrewing them?
10 replies so far
View Rich's profile
Rich
2068 posts in 459 days
#1 posted 08-18-2017 11:30 PM
It won’t be a problem. Use a screwdriver so you can feel when it’s tight.
-- No matter how much you push the envelope, it'll still be stationery.
View Desert_Woodworker's profile
Desert_Woodworker
1288 posts in 1084 days
#2 posted 08-18-2017 11:30 PM
Can you use 5/8” instead of 1/2” screws?
-- Desert_Woodworker
View papadan's profile
papadan
3584 posts in 3238 days
#3 posted 08-18-2017 11:48 PM
If you are worried, just stick a tooth pick in each hole and break it off. That will tighten them for sure.
one60fourth
#4 posted 08-19-2017 12:08 AM
I can’t use 5/8” screws but the toothpick idea should give me the guarantee I want. I’m tend to agree with RichTaylor that I could just rescrew but a little extra wood in the hole can’t hurt. Thanks for your comments.
View Rich's profile
Rich
#5 posted 08-19-2017 12:14 AM
I did the exact same thing for a vanity I built recently. I installed the euro hinges, got everything aligned, then took them off for staining and they went back on just fine. Mine was made of alder, which is very close in hardness to poplar. I don’t like the toothpick idea for little screws like that since it knocks things off-center.
Desert_Woodworker
#6 posted 08-19-2017 01:53 AM
I agree with RT on this- Unless they have a pathway or pilot hole to follow, from my experience they go cockeyed. Also remember not to torque too much or you will strip out the pilot hole. Should this happen drill out the original hole and glue in a piece of dowel rod, use your Vix bit to center the pilot hole and it will be as good as new.
View clin's profile
clin
767 posts in 866 days
#7 posted 08-19-2017 03:57 AM
Unless you over-tightened them the first time, no reason you shouldn’t be able to remount the hinges. As mentioned, if you strip one here or there. Fill it in , re-drill a pilot hole with a Vix bit. No harm done.
-- Clin
View Bluenote38's profile
Bluenote38
251 posts in 258 days
#8 posted 08-19-2017 01:13 PM
- papadan
That trick brings back the time I spent with an old carpenter. it works great especially with a bit of water to make the wood fibers swell. Btw Clin is right , don’t crush it and you don’t have to worry
-- Bill - Rochester MI
one60fourth
#9 posted 08-19-2017 02:23 PM
great comments! I used self-centering drill bits for the pilot holes and would like to maintain those centers. I’ll proceed carefully. Will be painting all day today and re-installing hinges tomorrow. Thanks!
View AlaskaGuy's profile
AlaskaGuy
3752 posts in 2179 days
#10 posted 08-19-2017 11:23 PM
It won t be a problem. Use a screwdriver so you can feel when it s tight.
- RichTaylor
+1
