table saw problem
« back to LumberJocks.com Site Feedback forum
Forum topic by brutus posted 01-15-2011 04:38 PM 1130 views 0 times favorited 12 replies Add to Favorites Watch
View brutus's profile
brutus
7 posts in 2567 days
01-15-2011 04:38 PM
i have a steel city 3hp table saw that bogs durning simple rips. i checked everything but the motor. has anyone out there had this problem?
12 replies so far
View tchaser's profile
tchaser
37 posts in 2568 days
#1 posted 01-15-2011 04:48 PM
Is the wood binding, in order to check the motor you need a clamp meter to check amp draw on both legs of power supply. on an under powered saw I had a similar problem. this would be a to man job with the saw running under load. I switched to freuds thin kerf teflon coated blade and that solved the problem.
-- bad projects make good firewood
View bigike's profile
bigike
4053 posts in 3165 days
#2 posted 01-15-2011 05:20 PM
need more info like, how thick is the wood? what type of blade are you using?
View canadianchips's profile
canadianchips
2600 posts in 2874 days
#3 posted 01-15-2011 06:10 PM
What kind of blade are you using?
Is the blade sharpened and “SET” properly ?
Is the fence aligned with the blade. ?
Is it belt drive or direct drive motor?
Is the motor low voltage or high voltage ?
How long is the extension cord you are using ?
Is the cord in good shape ?
What kind of wood are you trying to rip ?
Is the wood Dry or damp ?
View David175's profile
David175
101 posts in 2566 days
#4 posted 01-15-2011 06:13 PM
if this is a 220 volt saw….make sure 1/2 of the breaker didnt trip….Ive had it happen before
-- Dave..Pensacola Fl.........In GOD we trust
View richgreer's profile
richgreer
4541 posts in 2951 days
#5 posted 01-15-2011 07:33 PM
Others have already made some good points and asked a lot of questions.
I will add that some woods have a built in tension that releases when sawing to squeeze the blade. The answer to that is a riving knife or a splitter. Are using either?
View ajosephg's profile
ajosephg
1880 posts in 3438 days
#6 posted 01-15-2011 08:38 PM
One more question: Has it always done this, or is it a new problem?
-- Joe
View Loren's profile
9776 posts in 3525 days
#7 posted 01-15-2011 09:02 PM
If it cuts 3/4” hardwood ply okay but burns and bogs down in
solid wood, you may have some weird wood with a lot of
internal stress. In my times I’ve had some boards that were
simply not rip-able on a table saw due to internal stress.
View miles125's profile
miles125
2180 posts in 3882 days
#8 posted 01-15-2011 09:09 PM
Could just be a loose belt slipping at a specific load.
-- "The way to make a small fortune in woodworking- start with a large one"
brutus
#9 posted 01-15-2011 09:18 PM
david 175 what did you do to solve breaker problem.
View Knothead62's profile
Knothead62
2581 posts in 2838 days
#10 posted 01-16-2011 02:19 AM
David, I have never seen a double pole breaker that didn’t have the two levers connected. How did a half breaker trip?
As for an answer to the question, it has been covered thoroughly. Thank goodness for LJ’s!
David175
#11 posted 01-16-2011 02:28 AM
just turn it off then back on…..its worth a try
canadianchips
#12 posted 01-16-2011 03:58 AM
I’ve seen “home handyman” do his wiring and use two single breakers to make 220. PLEASE don’t do this ! But it happens ! I have also seen where they used a double pole breaker to run 110 volt . THIS IS EVEN WORSE .
People do the strangest things to save a dollar !
