Finding Antique Plane Irons
« back to Hand Tools forum
Forum topic by Bill Berklich posted 08-18-2017 10:48 AM 651 views 0 times favorited 4 replies Add to Favorites Watch
View Bill Berklich's profile
Bill Berklich
476 posts in 588 days
08-18-2017 10:48 AM
So I cleaned up a box of old moulding planes and came out with a great Ohio Tool No. 47 dado plane. It cleaned and sharpened very nicely but it is missing an iron. Hard to see in the picture but there is a secondary iron in front that leads the cutter. In the picture you can see the mouth just under the stop. I assume it’s a nicker??
Anyone know if where I can find one? Or have a picture? I’ve looked on eBay but because I don’t know what it looks like I can’t really figure out if anything listed would actually work nor can I fabricate a new one.
Barring a pic, I’m going to get some steel and a file and fake it.
-- Bill - Rochester MI
View EricTwice's profile
EricTwice
246 posts in 733 days
#1 posted 08-18-2017 12:20 PM
those wooden planes were generally hand made and the cutter was custom to the unit. If it needs a blade, you will need to make one.
If it were me I would start with a file, and put it in the oven at 450 Degrees F. for half an hour. This will give it the correct temper. (files are too brittle to use without retempering.)It will be a light yellow brown when you are done. (straw) It should be about about Rc 63. it will not file well. but will hold an edge and be less likely to chip.
Then I would sand top and bottom to remove the teeth, after that, grind it to shape
-- nice recovery, They should pay extra for that mistake, Eric E.
Bill Berklich
#2 posted 08-18-2017 12:23 PM
- EricTwice
I was afraid that might be the case. Any idea what the blade looks like?
View knockknock's profile
knockknock
458 posts in 2373 days
#3 posted 08-19-2017 04:08 PM
... Any idea what the blade looks like?
- Bluenote38
From your description, it sounds like your knicker blade may be like the one in this discussion:
http://www.woodcentral.com/woodworking/forum/archives_handtools.pl/bid/3106/md/read/id/84672/sbj/wooden-dado-plane-build-question/
Edit: I forgot to add: If the blade is like that, you might be able to make it out of a blank from Lie-Nielsen:
https://www.lie-nielsen.com/nodes/4142/tapered-molding-plane-iron-blanks
Bill Berklich
#4 posted 08-19-2017 09:46 PM
- Bluenote38
- knockknock
Looks perfect – I just need to scale it for a 1/2” I’ll check LN thanks.
