1-1/2" Radius Curve
Forum topic by Bohaiboy posted 08-18-2017 01:47 AM 777 views 0 times favorited 24 replies Add to Favorites Watch
View Bohaiboy's profile
Bohaiboy
76 posts in 1909 days
08-18-2017 01:47 AM
I need to cut a 1.5” radius curve for a piece of an apron for a table. See pic. I would cut it prior to final dimensioning teh wood to lengths and width so i would have a centering base. Should I buy a 3” forstner bit or hole saw, or just wing it with band saw qand then shape it out on the oscilalting sander.?
-- Tim, Houston, TX area
24 replies so far
View josephf's profile
josephf
202 posts in 2212 days
#1 posted 08-18-2017 01:52 AM
make a template and then use a router with the template on the actual project .
View Loren's profile
10477 posts in 3763 days
#2 posted 08-18-2017 02:08 AM
For just a few parts I would band saw it out
and clean it up with files and sandpaper.
You can get a tool called a fly cutter that
adjusts for cutting circles on a drill press.
It won’t cut as fast a a dedicated hole saw
or drill bit, but the size is variable.
View bandit571's profile
bandit571
21031 posts in 2799 days
#3 posted 08-18-2017 02:16 AM
Forstner bit.
View Rich's profile
Rich
3523 posts in 705 days
#4 posted 08-18-2017 03:41 AM
I like the router template idea Joseph had, but you’ll need a combination flush trim bit. Going into the grain with a flush trim bit is an invitation for nasty kickback — like across the room. Gotta go with the grain.
Second choice is the bandsaw and oscillating sander. It won’t be as perfect, but if you’re careful, it’ll pass.
View jbay's profile (online now)
jbay
2582 posts in 1014 days
#5 posted 08-18-2017 03:53 AM
Jig saw (or band saw) and oscillating sander if you have them.
You need to do the same thing to make a router template anyway.
Since you only have 2 to do, just cut em and sand em up and be done.
Bohaiboy
#6 posted 08-18-2017 04:16 AM
Actually have 8 to do, 4 aprons with one on each end/
View Rich's profile
Rich
#7 posted 08-18-2017 04:20 AM
- Bohaiboy
Router template. It’ll give you perfectly consistent results.
View dhazelton's profile
dhazelton
2789 posts in 2412 days
#8 posted 08-18-2017 11:55 AM
Band saw or jig saw. Could probably even use a coping saw.
View EricTwice's profile
EricTwice
237 posts in 649 days
#9 posted 08-18-2017 12:22 PM
there are 100 ways to do anything and if it works it’s right
I vote bandsaw and sandpaper
-- nice recovery, They should pay extra for that mistake, Eric E.
View JIMMIEM's profile
JIMMIEM
42 posts in 957 days
#10 posted 08-18-2017 12:23 PM
Check this out. It will show how to make the template you need. I made mine form 1/2” MDF. http://www.woodworkerz.com/curved-corner-edging/
View Carloz's profile
Carloz
1147 posts in 707 days
#11 posted 08-18-2017 12:56 PM
- jbay
There is a big difference between cutting a curve in a 1/4” sheet of mdf and doing the same on the actual piece,
jbay
#12 posted 08-18-2017 01:34 PM
- jbay
- Carloz
Not Really!
Maybe if you have a crappy jig saw and don’t use the correct blade, otherwise it’s just as easy.
Tim,
Seeing that you have 8 of them to do, I would probably set up a hole saw
(or forstner bit ) and cut them on the drill press.
If you do make a template and rout them, precut them close to the line so that your not hogging off a lot of material, that will make them go much easier.
View johnstoneb's profile
johnstoneb
2999 posts in 2288 days
#13 posted 08-18-2017 01:35 PM
Forstner bit or hole saw.
This will get you the exact same size and placement. The forstner bit would be a little faster than the hole saw and probably a cleaner hole. The large forstner bit are not that expensive.
-- Bruce, Boise, ID
View waho6o9's profile
waho6o9
8348 posts in 2692 days
#14 posted 08-18-2017 01:55 PM
Stack both apron lengths together and bandsaw them and sand to your liking.
Rinse and repeat. Done
View Rich's profile
Rich
#15 posted 08-18-2017 02:18 PM
- jbay
You do the same thing to make a router template… once. Then, the production pieces are quick, easy, and consistent. Besides, he said he has 8 to do, not 2.
