Driving Cut Nails
« back to Hand Tools forum
Forum topic by Jackcarter0714 posted 08-17-2017 10:44 PM 772 views 0 times favorited 19 replies Add to Favorites Watch
View Jackcarter0714's profile
Jackcarter0714
17 posts in 307 days
08-17-2017 10:44 PM
I’m building two dovetailed planter boxes. All of the joints are solid and ready to go. I’m nailing the bottoms on the sides, so that the bottom in inside the box rather than being directly under the sides. I’m using 8D cut nails. I don’t trust the strength of modern wire nails. Admittedly, these are meant for masonry, but they’re as close to the real thing as I can get. I go to drive in the first nail, it goes in about 3/8ths and stops, a dead stop. Does anyone know any tricks to driving these nails? I drilled a pilot hole the thickness of the nail, and am nailing it in with the grain.
19 replies so far
View Ron Aylor's profile
Ron Aylor
2127 posts in 553 days
#1 posted 08-17-2017 11:23 PM
May I assume your pilot hole went through the side into the bottom? How thick are the sides? How thick is the bottom? What species lumber are you using? Cut nails do need a pretty good wallop!
I usually put a bit of grease (boiled linseed oil and bee’s wax) in the pilot hole before driving the nail.
-- Ron in Lilburn, Georgia.  Knowing how to use a tool is more important than the tool in and of itself.
Jackcarter0714
#2 posted 08-17-2017 11:41 PM
I usually put a bit of grease (boiled linseed oil and bee s wax) in the pilot hole before driving the nail.
- Ron Aylor
The lumber is 4/4 pine. The hole goes through the side and the bottom. I just might have to try that grease trick. The last board split on me after forcing it with a heavier hammer.
View ArtMann's profile
ArtMann
833 posts in 721 days
#3 posted 08-18-2017 01:31 AM
Why not use stainless steel screws or silicon bronze ring shank boat nails? I think your real problem is going to be rust rather than weak fasteners.
Jackcarter0714
#4 posted 08-18-2017 01:40 AM
- ArtMann
Screws hold the wood too tight. They would never allow for enough wood movement. The wood would be splitting after a matter of days.
Those nails have no taper, just like a wire nail. That means there is nothing wedging to hold the wood. The wood is virtually free floating on the nail when using untapered nails.
Rust, or rough surfaces rather, on nails is desirable. A nail that is too slick has no texture to grip the wood.
View bandit571's profile
bandit571
19200 posts in 2589 days
#5 posted 08-18-2017 02:12 AM
Maybe as simple as turning the nail 90 degrees, so it doesn’t wedge the wood apart?
Jackcarter0714
#6 posted 08-18-2017 02:17 AM
Maybe as simple as turning the nail 90 degrees, so it doesn t wedge the wood apart?
- bandit571
I wish it was, man. The nail is already aligned with the grain.
View TheFridge's profile (online now)
TheFridge
8886 posts in 1391 days
#7 posted 08-18-2017 03:13 AM
Lie Nielsen carries cut nails.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2214 days
#8 posted 08-18-2017 06:08 AM
To go along with bandit’s suggestion
http://www.tremontnail.com/faqs.htm
MrUnix
6351 posts in 2104 days
#9 posted 08-18-2017 06:13 AM
I hate those things! The trick is usually to get a bigger hammer :)
AlaskaGuy
#10 posted 08-18-2017 06:13 AM
Ron Aylor
#11 posted 08-18-2017 10:13 AM
- Ron Aylor
- Jackcarter0714
You might also consider using 6d nails with the 4/4 pine … just a bit thinner. Good luck … and don’t forget to post your planters!
View tomsteve's profile
tomsteve
753 posts in 1124 days
#12 posted 08-18-2017 01:24 PM
- Jackcarter0714
i have 7 year old planter boxes on my deck i assembled with stainless screws. not one spilt through 7 years of michigan weather.
im willing to bet that those nails will work their way out.
if your wood splits after a matter of days, youre starting with too high an MC in your wood.
i dont think cut nails are intended for exterior wood work.
as you stated- they are meant for masonry and say that for a reason.
why not assemble the project like millions of people have built outdoor projects for years and years?
Jackcarter0714
#13 posted 08-18-2017 05:05 PM
- Jackcarter0714
- tomsteve
Was the planter sealed? That’s interesting. That problem with splitting is that you start with dry wood, and introduce the constant water later. The reason for using cut nails is to practice technique for period furniture. Practicing on small, unimportant projects is much better than messing up on the real thing.
Ron Aylor
#14 posted 08-18-2017 06:24 PM
... the reason for using cut nails is to practice technique for period furniture. Practicing on small, unimportant projects is much better than messing up on the real thing.
- Jackcarter0714
Now you’ve gone and opened up that can of worms. Oh my! Please be prepared for every Internet Troll on this site to offer complaint, criticism, and their unasked-for advice about how you are not building period furniture  correctly or truly period … been there, done that!
I for one shall look forward to seeing your efforts and hope you will learn to ignore the inevitable barrage. Keep it up and good for you!
View Dave Polaschek's profile
Dave Polaschek
1537 posts in 487 days
#15 posted 08-19-2017 12:10 AM
Brooklyn Tools & Craft sells cut nails, too. Just ordered three pounds of them myself. Don’t have any tips to offer yet, but maybe in a few weeks….
-- Dave - Minneapolis
