Uneven cut when cutting off box tops
« back to Joinery forum
Forum topic by SiRiC posted 08-17-2017 10:19 AM 1052 views 0 times favorited 15 replies Add to Favorites Watch
View SiRiC's profile
SiRiC
8 posts in 2142 days
08-17-2017 10:19 AM
Topic tags/keywords: box
Hi,
I make boxes and cut off the tops on the saw. I use the method of cutting just shy of the wall thickness so that there is a sliver to hold the top until the process is complete.
What I find however, is that when I make the second cut, it tends to be off by a tiny fraction giving a slight lip between the two sides.
https://s3.amazonaws.com/vs-lumberjocks.com/outr89p.jpg
I have tried cutting the sides sequentially, tried cutting opposite sides but it really does not make a difference.
Would appreciate any insight into solving this.
Thanks
Steve
-- Measure twice...ummm.. i forget the rest!!
15 replies so far
View Andy McCormick's profile
Andy McCormick
31 posts in 3716 days
#1 posted 08-17-2017 10:57 AM
Your bottom of the box is not flat. If it’s not flat it will transfer the unevenness to the cut.
-- Andy, Liberty,Indiana, www.mccormickwoodworking.com
View dhazelton's profile
dhazelton
2789 posts in 2417 days
#2 posted 08-17-2017 11:02 AM
I’d say your blade is not at 90 or the fence moved on you.
View Gene Howe's profile
Gene Howe
10840 posts in 3549 days
#3 posted 08-17-2017 11:29 AM
To eliminate the problem, finish the cuts with a hand saw or sharp knife.
View Aj2's profile
Aj2
1664 posts in 1919 days
#4 posted 08-17-2017 12:37 PM
Bandsaw does a better job. Thinner Kerf one pass and it done.
With a table saw you have to keep rotating around the mismatch your seeing is how flat your bottom is.
Just as Andy Mc Cormick mentions.
-- Aj
View hotbyte's profile
hotbyte
991 posts in 3096 days
#5 posted 08-17-2017 12:46 PM
Could fence to blade alignment also have an impact on final cut alignment???
View jeffswildwood's profile
jeffswildwood
3484 posts in 2098 days
#6 posted 08-17-2017 01:06 PM
I think fence alignment would make a mis cut on all four corners. I go with bottom not flat. Just a little off will do this. I too have had this happen, It’s a bear to fix!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View Carloz's profile
Carloz
1147 posts in 712 days
#7 posted 08-17-2017 01:09 PM
I have a question for you too. How do people manage to make 3 post on the forum in 5 years ?
View rwe2156's profile
rwe2156
3073 posts in 1601 days
#8 posted 08-17-2017 01:15 PM
There are a several factors but I doubt it is the saw.
If the reference face of the box against the fence isn’t 1) perfectly parallel, 2) or if the bottom is not perfectly flush, 3) the sides are not perfectly square to each other.
I would still double check the blade-to-fence for parallel.
View Dan's profile
Dan
722 posts in 2013 days
#9 posted 08-17-2017 01:25 PM
If the insert is not perfectly flush, or like rwe2156 says, “if the sides are not perfectly square” focus more on pushing box against fence while running through.
-- Dan
View Redoak49's profile
Redoak49
3455 posts in 2109 days
#10 posted 08-17-2017 01:35 PM
For a long time, I used the table saw to cut off box tops. I switched to use the bandsaw and it is much better. I use spray adhesive and attach a sheet of sand paper to 1/4” MDF. I use this for sanding the bandsaw cuts smooth. This method works much better for me.
View BurlyBob's profile
BurlyBob
5897 posts in 2386 days
#11 posted 08-17-2017 01:50 PM
I use a piece of a wide sander belt – 24”, clamped to my table saw. I sand the bottom flat so the box sits with no rocking. Once I cut the lid I do the same thing to the lid and box. Makes for a nice fit.
View Ripper70's profile
Ripper70
1115 posts in 1029 days
#12 posted 08-17-2017 02:44 PM
Here are two methods that may work for you:
How to Saw Off a Box Top
Cutting a Lid from a Box
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View tmasondarnell's profile
tmasondarnell
97 posts in 1910 days
#13 posted 08-17-2017 05:17 PM
Steve,
I was having the same issue and found that it was caused by two problems already identified:
1. The bottom of the box was not flat.
2. I was not keeping the box tight to fence—particularly on the short cut.
SiRiC
#14 posted 08-17-2017 05:37 PM
Thanks for all of the responses!!
I make sure to keep the box tight to the fence, so it is most probably the flatness of the box.
Had tried the band saw and it was easier but the teeth marks afterwards kind of deterred me – will try again though as it easier to sand the marks than having to correct the incorrect cut from the tablesaw.
@Carloz, did not realise that I was an offender for not posting regularly!!
Thanks again,
Steve
View Jim Finn's profile
Jim Finn
2670 posts in 3043 days
#15 posted 08-18-2017 08:49 PM
”.....Had tried the band saw and it was easier but the teeth marks afterwards kind of deterred me ….”
Thanks again,
Steve
In the past 9 years I have made, and sold, well over 2000 boxes and I cut the tops off with a band saw. I then lightly sand the cut, with a random orbital sander, to remove the saw marks and move on to the next box.
-- No PHD just a DD214 Website> craftingcouple.com
