Best hinges for a box?
Forum topic by Tyler posted 859 days ago 1630 views 0 times favorited 9 replies Add to Favorites Watch
View Tyler's profile
Tyler
172 posts in 863 days
859 days ago
I built my wife a keepsake box almost a year ago and I still have yet to put hinges on it! Kind of embarrassing really…. The only hinges I could find around town were the cheap brass hinges, typically intended for craft items I believe.
Anyway, I’m wondering what kind of hinges are best and where to get them? I’ve seen some small cylinder-like hinges that look nice but I can’t find them and I don’t know what they are called. I’ve also seen the quad hinges that look nice but not sure I’m skilled enough to install them :-).
The box is made of walnut and is about 1/2” thick, 9” wide by 5” deep and about 5” high. I have already cut the lid and I’m not looking to make any design changes to accommodate hinges.
Any and all ideas welcome!
9 replies so far
View FaTToaD's profile
FaTToaD
236 posts in 1311 days
#1 posted 859 days ago
I would look into Brusso hinges. You can find them here at Rockler. They’re pricey compared to the cheap hinges you’ll find at local hardware stores, but they are worth it. I used my first set on this box, and I was very happy when them. If you’re going to spend all the time and effort on a box that’ll last several lifetimes, you might as well put quality hardware on it. And trust me, you’ll love these hinges.
David
-- David
View levan's profile
levan
312 posts in 1149 days
#2 posted 859 days ago
You might want to consider making your own out of wood. There are some really neat ones on here. Just do a search for wooden hinges.
-- Lynn "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View RogerBean's profile
RogerBean
757 posts in 1123 days
#3 posted 858 days ago
For some time now, I’ve been using only side rail hinges from bcspecialities.com. They are available in quadrant or stop-hinge without the quadrant. In two sizes. Both will work fine with 1/2” stock using a 5/16” router bit. These are machined from solid brass and gold plated and suitable for the finest box. They are also easier to install perfectly. They are about $30/pair. Brusso’s are well made, but the quadrants will be difficult to install perfectly without their router jig. But then, you may prefer their regular stop hinges. Hope this helps. Good luck.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
View kodiak's profile
kodiak
55 posts in 1191 days
#4 posted 858 days ago
lots of different kind of hinges at Lee Valley
these are the barrel hinges
http://www.leevalley.com/en/hardware/page.aspx?p=64335&cat=3,41241,41265
http://www.leevalley.com/en/hardware/page.aspx?p=62129&cat=3,41241,62129
-- Simple advice is the best advice
View richgreer's profile
richgreer
4474 posts in 1244 days
#5 posted 858 days ago
The cylinder type hinges you are talking about are probably barrel hinges like these – -
http://www.rockler.com/product.cfm?page=270&filter=barrel%20hinges
I’ve used them in the past. Note that they are metric and you really need a metric drill bit. Also, I advise that when you first put them into the hole, make sure you have them aligned right. It is sometimes very difficult to pull them out or rotate them once they are in place (even before you tighten them down).
View Joe Lyddon's profile
Joe Lyddon
6395 posts in 2222 days
#6 posted 858 days ago
R Geer,
I bought some of those 5mm hinges from Woodcraft… and have been having a little problem getting a true 5mm brad point bit. They are very tricky to install.
I finally went to a simple 1/2 x ~1/4 Pin hinge As in this box I was making.
I’ve liked this type of hinge so well, I have made a few more with it…
richgreer
#7 posted 858 days ago
I did not know they made those hinges in 5 mm. That’s about 3/16”. That’s very small. I’ve never used anything smaller than 10 mm.
I have also used the pin hinge that you like and for certain situations I really like it. In terms of style, the pin hinge may be a little more casual and the barrel hinge can be a little more formal.
Joe Lyddon
#8 posted 858 days ago
I agree, Rich…
Those BOSS hinges are sure Formal looking… and expensive too… never used them… just looked….
Tyler
#9 posted 858 days ago
Thanks for all for the ideas. I do like the pin hinge and plan on trying that in the near future. For this box, I want a slightly more formal look and will likely try the barrel hinge or quadrant hinges. Although those Brusso hinges look nice to. Whatever I do I’ll install the hinges on a test box first!
This was my first forum post and I received some great information. Thanks LJs!
