| Forum topic by Alongiron | posted 886 days ago | 459 views | 0 times favorited | 2 replies | ![]() |
886 days ago |
I have a Rigid DP-1550 stationary drill press. The chuck locked up so I had to get a new one. So I got the old one off and when I put the new one on it seems to be a little off. I can notice the point of the drill bit to have maybe 1/64” wobble at the end. This does not seem to be normal. Any ideas? Thanks -- Measure twice and cut once..... |
2 replies so far
#1 posted 886 days ago |
Check with another bit, if you haven’t done it yet. I bought some cheap Ryobi bits and I noticed the brad point was wobbling. I checked the bit – just rolled it on a flat surface. Sure enough, it was bent. |
#2 posted 886 days ago |
test this with your largest bit to minimize the possibility of it being a bent drill bit. If you still experience wobble. it could very well be that the chuck is not set properly in the drill, especially since you state that you noticed this after replacing the chuck. If it is the chuck – take it out (firmly but carefully not to damage it), clean off ALL debris, lubrication, and anything that may be on the arbor/chuck/socket – the chuck is held by friction and friction alone (morse/jacobs tapers work that way) and any microscopic particle (to dramatize it) will take it off center. point is – make sure everything is super clean, and not lubricated or anything – gotta be dry. now put the chuck back in the socket put it up while giving it a bit of rotation action to snug it up straight. now place a scrap piece of flat board on the drill table, raise the table until the chuck kisses the piece of wood. using slow speed on the DP start it up and press the chuck down against the piece of wood (make sure wood is secured to the table) just to cause the chuck to press tightly into the socket. the rotation of the chuck will make sure it is evenly pushed in. hope this helps. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
| Forum | Topics |
Woodworking Skill Share
8844 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1599 |
3593 |
15974 |
Hand Tools
2094 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2773 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6131 |
