Grizzly parts on Jet Lathe
« back to Woodturning forum
Forum topic by khesidenz posted 08-16-2017 08:13 PM 461 views 0 times favorited 4 replies Add to Favorites Watch
View khesidenz's profile
khesidenz
5 posts in 314 days
08-16-2017 08:13 PM
Wondering if anyone has had any experience using Grizzly parts on a Jet lathe. Grizzly’s 10×18 lathe looks nearly identical to the Jet 1014 and/or 1015. Parts from Grizzly are significantly less expensive and based on the schematics, the tailstock, tool rest and all bolts/handles/etc. look interchangeable.
Thanks for any replies with experience.
-Kris
View REO's profile
REO
928 posts in 2102 days
#1 posted 08-17-2017 12:13 AM
Depends on the specific parts. the banjo may be a universal part but the ways may have a different spacing. the bore on the quill may be different. What do you need specifically?
khesidenz
5 posts in 314 days
#2 posted 08-17-2017 12:55 AM
I need the full tailstock and full tool rest/banjo assembly.
A bit of backstory… I picked up two Jet 1014 lathes (one 1014, one 1014vs) from a gentleman that was retiring from turning. The 1014 was a full machine with all parts. The 1014vs, on the other hand, was/is missing the entire tailstock and tool rest/banjo assemblies.
I have called several local Jet repair centers, scoured the online part suppliers and posted Wanted to Buy (WTB) threads on a few woodworking sites.
Parting out the needed pieces through local repair centers or online part suppliers would be about $250 for Jet parts.
Grizzly parts would be around $125.
Since I need the entire tailstock assembly, including the quill, I’m hoping that the parts are reasonably interchangeable.
Both lathes have been cleaned, rust removed, lubricated, given a new coat of color matched Jet ivory paint, and are running like tops.
I would love to find the needed parts, at a reasonable price, so that I could get the lathe restored and give to my father as a gift.
View MrUnix's profile
MrUnix
6768 posts in 2227 days
#3 posted 08-17-2017 12:58 AM
The Harbor Freight lathe is exactly the same as the Grizzly, but in a different color… so just run down to your local HF and do some measuring.
khesidenz
5 posts in 314 days
#4 posted 08-17-2017 01:04 AM
Thanks for the HF recommendation. I will check it out.
