Tool Chalenge! WTF is this?
« back to Hand Tools forum
Forum topic by AndrewBarron posted 08-16-2017 03:48 PM 1375 views 0 times favorited 19 replies Add to Favorites Watch
View AndrewBarron's profile
AndrewBarron
2 posts in 521 days
08-16-2017 03:48 PM
Seriously. 11” in diameter. Can’t figure out what this is. HELP!!!
19 replies so far
View Loren's profile
10477 posts in 3884 days
#1 posted 08-16-2017 04:08 PM
Milling table of some sort perhaps. The groove
would catch oil used in cutting.
AndrewBarron
2 posts in 521 days
#2 posted 08-16-2017 04:11 PM
I don’t think so. Zoom in on the picture and you will see a series of lines running tangential to the centre with gradient marks from 1 to 75 (outside to in). There is 16 marks per ‘ring’. I’m thinking some sort of scribing tool? Or possible a spring gauge?
View pintodeluxe's profile
pintodeluxe
5816 posts in 3050 days
#3 posted 08-16-2017 04:13 PM
Looks like an old drill press table.
View Aj2's profile
Aj2
1950 posts in 2035 days
#4 posted 08-16-2017 04:35 PM
Looks like a faceplate to a lathe special made for a top secret operation.
-- Aj
5234 posts in 2730 days
#5 posted 08-16-2017 06:10 PM
I’ve seen milling plates designed to make gears that had such markings. That allowed the operator to rotate the piece exactly the correct distance to cut the next tooth in the gear. I think it may have been called a “rotary table”.
View AlaskaGuy's profile
AlaskaGuy
4989 posts in 2546 days
#6 posted 08-16-2017 06:32 PM
F if i know
View Gene Howe's profile
Gene Howe
11143 posts in 3665 days
#7 posted 08-16-2017 06:46 PM
F if i know
- AlaskaGuy
Ditto
MrUnix
7106 posts in 2436 days
#8 posted 08-16-2017 07:03 PM
Looks vaguely like the scroll wheel for a lathe chuck. But the graduations marked along the spiral start at one and work their way along the spiral up to seventy something… so perhaps an index pin runs along the spiral and moves the opposite end a fixed amount that is roughly measured on the spiral… otherwise, I got nothing :(
View msinc's profile
msinc
569 posts in 740 days
#9 posted 08-16-2017 08:46 PM
Removable middle of a router table???? Looks like you might bolt the router to it and drop both down into the cutout in the middle of the table…kind of like my Bosch only it is square. Some older routers had a four bolt pattern on the bottom plate instead of three like the new ones.
When in doubt…throw it like a frisbee. One thing about it…if you don’t figure it out soon you don’t need it. I have gone 55 years without whatever the darn thing is and I cant see needing one if I happen to live another 55!!!!
View mudflap4869's profile
mudflap4869
1885 posts in 1696 days
#10 posted 08-16-2017 09:05 PM
A round tuit?
-- Still trying to master kindling making
View TungOil's profile
TungOil
1080 posts in 732 days
#11 posted 08-16-2017 09:07 PM
A round tuit?
- mudflap4869
I thought that at first, but I believe it to be a spiral framitz.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View DS's profile
DS
3045 posts in 2657 days
#12 posted 08-16-2017 09:20 PM
Looks like a back plate for a four jaw chuck.
At least it resembles the one I have (Mine is only 4” diameter though).
View papadan's profile
papadan
3584 posts in 3605 days
#13 posted 08-16-2017 11:02 PM
Andrew, I do believe you owe mudflap a cigar, he has the best answer to this thread! ;-)
runswithscissors
2924 posts in 2262 days
#14 posted 08-18-2017 04:05 AM
msinc: You say you have never needed this thing in 55 years of woodworking. But are you sure about that? Think back to the times when you didn’t have quite the right or best tool for some task. So you had to improvise or make do with something that was not quite suitable. Well, this is the tool you needed at those times. Could have been as recently as last week.
View MrRon's profile
MrRon
5263 posts in 3480 days
#15 posted 08-18-2017 07:32 PM
I believe it is a dividing plate used on a rotary table for gear cutting on a milling machine.
