any pictures or advice re:making router throat plates?
Forum topic by gfadvm posted 01-14-2011 06:17 AM 997 views 0 times favorited 6 replies Add to Favorites Watch
View gfadvm's profile
gfadvm
14940 posts in 2595 days
01-14-2011 06:17 AM
I made arouter table of birch ply without a plate.I now need to make throat inserts.This is my first attempt at posting .Thanks for any help.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3191 days
#1 posted 01-14-2011 11:44 PM
First of all, you can buy after market inserts, if you can find the right sizes.
If you make them, you might try a hole saw on a drill press for the outside diameter, assuming they are round.
Keep it clamped in place and go back and drill the inside hole the size you need. You could make them from wood, plastic, phenolic, etc.
Hope some of this helps
Good luck
-- http://shepherdtoolandsupply.com/
gfadvm
#2 posted 01-15-2011 03:02 AM
Kent
thanks for the comment.my throat diameter is 3 inches.I can make the inserts but havnt figuered out how to hold them in place.It gets too exciting when one lifts up,leaves,and,gets caught by the router bit.
gfadvm
View childress's profile
childress
841 posts in 3446 days
#3 posted 01-15-2011 03:52 AM
how about trying to hot glue it in. Make it a tad thinner and the glue will level it up…. Just a thought.
-- Childress Woodworks
View Richard's profile
Richard
1916 posts in 2595 days
#4 posted 01-15-2011 04:50 PM
what about a rabbet around the outside of the 3” and small screws to hold the plate, this is how my factory made plate goes in.
View bigike's profile
bigike
4053 posts in 3193 days
#5 posted 01-15-2011 05:43 PM
my guess would be a magnet, one small one if using rare earth mags. or you can put a rabbit and install threaded inserts for screws like racer2007 said. mine are friction fit they stay in cuz i made them tight and sanded them just enough to slide in and out with a little hand pressure, haven’t had a problem with them lifting.
gfadvm
#6 posted 01-17-2011 05:04 AM
did small button magnets and it worked!
Thanks,I wouldnt have thought of mags.
gfadvm
