Craftsman 113 for $300?
Forum topic by therest posted 08-16-2017 03:44 AM 1863 views 0 times favorited 25 replies Add to Favorites Watch
View therest's profile
therest
11 posts in 521 days
08-16-2017 03:44 AM
Hello everyone! I’m new here and looking forward to learning a lot from all you guys. I’m also new to woodworking and I’ve been reading a lot about table saws. My main purpose for this table saw is to create some cabinets for my restroom and kitchen cabinets. I know that I want something pretty dead accurate and read a lot about a belt driven motor table saw is best. I can’t afford a new table saw as the R4512 or the 36-275 so here I am. So I found this deal and was wondering what do you guys think? Is it a fair price? Will it suit my needs? TIA everyone.
https://houston.craigslist.org/tls/d/table-saw/6246638739.html
25 replies so far
View bandit571's profile
bandit571
21986 posts in 2920 days
#1 posted 08-16-2017 04:04 AM
Maybe for the seller…I’d offer them about half that.
They are very good saws….
View jimintx's profile
jimintx
864 posts in 1821 days
#2 posted 08-16-2017 04:29 AM
Some people think the used tool prices in their area apply all over the country. I can say from a long time of personal experience, the market around Houston is not as soft for tools as it apparently is in some other places. Decent stuff is very hard to find, and even crappy stuff is overpriced.
If that saw is in good shape it will do well, and it has some good accessories. Maybe you can get it for a lower offer. It is always worth the effort to negotiate as well as you can.
-- Jim, Houston, TX
therest
#3 posted 08-16-2017 05:31 AM
Bandit571, thanks. He’s brought the price down a bit.
Jim, I feel the same way too. Most table saws, and probably most tools, are priced very close to new if not more considering inflation. He has brought the price down to $250. What are some tips in inspecting a table saw’s condition?
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#4 posted 08-16-2017 05:48 AM
Around here, that is a $100 saw… keep in mind that you probably miss 99% of the good deals, so what you are seeing are not :)
Notice that the saw in question has sat out there for two weeks already… there is your hint.
View Gilley23's profile
Gilley23
489 posts in 619 days
#5 posted 08-16-2017 06:06 AM
Make sure that the blade lowers and raises all the way and that it tilts from 90°-45° with normal effort (no binding).
Inspect the belt for cracks and the condition of the saw’s blade. (Just something to look for to possibly help negotiate the price down)
Power up the saw and listen to it, it should be smooth running. Any clicks or bumps could indicate that it needs new arbor bearings.
Cut a piece wood with it to check for overall condition
Inspect the power cord and plug end
Check the mobile base
View Clarkie's profile
Clarkie
467 posts in 2078 days
#6 posted 08-16-2017 10:13 AM
Hello therest, that saw sold for 359.00 when it was new. It will cut wood, but, I’d hold out for a Delta contractor saw an older model. Craftsman was made for the weekend woodworker, in the 40’s and 50’s they were a much beefier product and stood up well. If you feel you have to buy this one, I’d offer 125.00 and keep looking if he declines. You’ll find a big difference between a older Delta or Powermatic product than Craftsman. Just my opinion but, when you have quality equipment it seems to instill a desire to do quality work. Have fun, make some dust.
View JCamp's profile
JCamp
893 posts in 787 days
#7 posted 08-16-2017 11:01 AM
To me the $300 is to much if it was just the saw. I paid $90 for mine with a factory fence but since that saw has probably a $200 vega fence the higher price is somewhat justified. To me the 250 doesn’t sound like to bad of a price especially if things are lean in your area. U wont find a new one that comes close for that price or even a $100 more.
Also I upgraded to my 113 from a cheap direct drive delta and the 113 is SOOOO much better. Im sure a unisaw will out cut the craftsman but the price will be that much higher too plus itll be 240Volt and not a 120v
If I was you id bite the bullet and buy the saw. You can always negotiate the price some more when you get there to look it over
-- Whatsoever thy hand findeth to do, do it with all thy might
View knotscott's profile
knotscott
8177 posts in 3612 days
#8 posted 08-16-2017 11:25 AM
I think $300 for that saw with the Vega fence is a fair price. Can’t hurt to offer closer to $250, or ask to include the mobile base. The Vega fence is excellent, has the blade guard, metal handwheels and grated cast wings. It’s the same basic saw as the Emerson Ridgid contractor saws, but with a better fence. I’d make an offer if it checks out.
If that one doesn’t pan out, here’s another option:
Looks like a 315 Craftsman contractor saw with cast router wing and upgraded fence – https://houston.craigslist.org/tls/d/craftsman-tablesaw/6247650505.html (asking $275)
Here’s another that could be worth a look if you can get the price down. Has the upgraded fence and solid cast wings, but also has some surface rust….that should clean up well, but is a good negotiating point. ~ $250
https://houston.craigslist.org/tls/d/craftsman-10-inch-table-saw/6211400338.html
View Bill Berklich's profile
Bill Berklich
501 posts in 625 days
#9 posted 08-16-2017 11:35 AM
$100 unless it’s got the extended 24/24XL fence and cast iron wings. Then as much as $250. It’s a good saw for a non-production home shop and will serve you will for years and more bang for your buck esp with the upgrade fence and wings. It is not however a 3HP or 5HP Cabinet saw then again you are paying 75% to 90% less.
Things to look at are 1) run out – does the arbor spin true. the norm for these saws are about .007” you’ll need a dial indicator to find out 2) bearing wear – if it was actually used the bearings may be worn. Grab the blade (UNPLUG the saw) wiggle it. It should be tight if not you’ll need to replace the bearings or look for a different saw. 3) belt wear – this will give you an indication of how much life the saw may have left. Worn belt = Worn saw 4) Blade parallel to the miter slot you – this will give you some insight into the trunnion condition and you will need either a dial indicator or a combination square and feeler gauges. About .003-.007 difference front to back on a fully raised 10” blade. (you are looking for 0.000” here but you can adjust it) 5) Crank the blade up and down fully and then 0 to 45 and back 6) how does it sound Remove the belt and had spin the blade You shouldn’t hear the bearings. Then hand spin the motor – same thing. Then run the saw with and without a load. You shouldn’t hear any weird sounds. Btw I usually bring my own blade – it’s easier for me to judge the sound and cut.
If you’re only paying $100 you really can’t be too picky. If you’re looking at $350 break out the fine tooth comb and look at everything. ~~ Good luck
Btw – looks like Gilley23 covered most of this
-- Bill - Rochester MI
therest
#10 posted 08-16-2017 01:19 PM
Thanks everyone.
knotscott, thanks for the finds. I had seen those, but they are quite a ways from me. The one i’m interested is quite a drive itself actually as well.
Bluenote38, man those are some great and specific tips.
I think the deals some of you find are very hard to come by. I’ve been looking on all selling media outlets constantly for a good week now. This is the trend in my area as far as pricing goes.
View johnstoneb's profile
johnstoneb
3070 posts in 2409 days
#11 posted 08-16-2017 01:38 PM
With the after market fence $250 is a fair price for that saw. The fence makes it into a good saw.
-- Bruce, Boise, ID
View ArtMann's profile
ArtMann
1216 posts in 1053 days
#12 posted 08-17-2017 12:01 AM
I owned a Craftsman table saw almost exactly like that one but with steel wings. It gave good service but the fence was very hard to adjust accurately. I gave mine to a friend but if I were trying to sell it, I would ask $150 with the upgraded fence.. That is what I believe it is worth.
therest
#13 posted 08-17-2017 02:00 PM
Thanks guys. I’m wondering if everyone saying it’s worth 125-150 realize what type of fence is on it.
View Tony1212's profile
Tony1212
267 posts in 1971 days
#14 posted 08-17-2017 02:42 PM
When I read the title of the thread, I thought to myself, “No way! Unless it has an aftermarket fence and the webbed cast iron wings.” Lo and behold…
I have a much older Craftsman 113 with a Vega Pro 40 fence. I’m very happy with it. The fence alone was $250.
-- Tony, SW Chicago Suburbs
jimintx
#15 posted 08-17-2017 03:17 PM
It is mostly a mistake to ask questions on LJ about what a used tool is worth. The real answer is always related to the real question, “What is it worth to me?” That incorporates what you want, what you like, what you know, and where you are.
I’d take that saw and its accessories for $250-$300 all day long before I paid for a plastic-based portable saw of modern manufacture. But that is my opinion. I had an early version of that saw, with its original cr*ppy fence for two decades and used it will great success – before spending the “big bucks” 17 years ago for a 3HP cabinet saw (it’s a Unisaw).
-- Jim, Houston, TX
