Expansion and contraction
Forum topic by Fireworker1205 posted 08-15-2017 03:10 PM 521 views 0 times favorited 5 replies Add to Favorites Watch
View Fireworker1205's profile
1 post in 217 days
08-15-2017 03:10 PM
New to the forum. I apologize if this was already discussed.
Im looking into build a kitchen table for my fire department. After watching a lot of videos i found that an issue occurs with the expansion and contraction of the wood over time. This table will have a decal with logos underneath a 1/4 inch layer of epoxy. The concern over the table cracking has left me perplexed on what is best to use.
My question for those more knowledgable is, would i be better off using plywood as the table top? Does plywood expand at a similar rate?
I am using 1×3 lumber as the edges of the table to clean up the look and im also putting them 1/4 inch up to create the sides to make the layer of epoxy. If the plywood does expand will that push those 1×3s outward and crack the epoxy?
5 replies so far
View Vindex's profile
91 posts in 754 days
#1 posted 08-15-2017 04:23 PM
Plywood is stable and does not have the same expansion/contraction issues as you would get making a tabletop out of solid planks. In fact, most commercially made tables are sheet goods (Plywood, MDF, etc.) with a veneer on top and some hardwood trim around the edges. I would say go for the plywood.
View TheFridge's profile
9079 posts in 1418 days
#2 posted 08-15-2017 04:25 PM
Use ply with epoxy used like that. It will not move noticeably.
View Monte Pittman's profile
Monte Pittman
28581 posts in 2270 days
#3 posted 08-15-2017 06:37 PM
Plywood should be fine.
Welcome to Lumberjocks
-- Mother Nature created it, I just assemble it.
View bondogaposis's profile (online now)
4633 posts in 2283 days
#4 posted 08-15-2017 08:34 PM
Plywood is stable and won’t give you issues like solid wood would. Plywood is recommended for your application.
-- Bondo Gaposis
View ArtMann's profile
900 posts in 748 days
#5 posted 08-17-2017 12:42 AM
There is a restaurant I go to from time to time that has tables made from glued up 6/4 red oak and covered in the poured epoxy you are talking about. I have yet to see a split or crack in any of them. I don’t know how they get by with it but they have zero problems. It may be that the epoxy has a certain amount of elasticity.
