Walnut and Hickory Box joint stability
« back to Joinery forum
Forum topic by Shirk99 posted 08-15-2017 10:21 AM 658 views 0 times favorited 2 replies Add to Favorites Watch
View Shirk99's profile
Shirk99
3 posts in 404 days
08-15-2017 10:21 AM
I am building a hope chest for my step daughter. My wife wants me to use hickory front and back with walnut sides with finger joints. Is this combination going to be stable? I believe hickory moves more than walnut?
Thank you
2 replies so far
View jdh122's profile
jdh122
1034 posts in 2935 days
#1 posted 08-15-2017 10:58 AM
It’ll be fine. By my calculation there’s about 1/1000th of an inch difference per inch of width with maximum seasonal contraction (from 8 to 14%). In reality it’s likely to be less, given the use of a finish and the fact that it’s unlikely that the moisture is at the maximum or minimum when built. Each individual finger will very easily absorb that much difference. In fact I doubt there really are wood combinations that are incompatible for this reason.
-- Jeremy, in the Acadian forests
View splintergroup's profile
splintergroup
2253 posts in 1340 days
#2 posted 08-15-2017 02:13 PM
I agree w/Jeremy. The shrinkulator shows roughly the same coefficients of expansion between the two woods
