scrapper angles
« back to Woodturning forum
Forum topic by Karda posted 08-15-2017 06:45 AM 761 views 0 times favorited 20 replies Add to Favorites Watch
View Karda's profile
Karda
874 posts in 425 days
08-15-2017 06:45 AM
Hi, I am making my own round nose scrapper, what angle should I grind it to, I have watched a number of videos but none I watched mentioned angle thanks Mike
20 replies so far
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1236 posts in 1585 days
#1 posted 08-15-2017 10:08 AM
Would love to help but not sure what you mean by round nose scrapper? A picture/drawing might help getting answers.
In genneral card scrapers and beading scrapers are ground to 90 degrees and scraper planes 45 before burnishing
-- "Do or Do not. There is no try." - Yoda
View LeeMills's profile
LeeMills
489 posts in 1172 days
#2 posted 08-15-2017 12:58 PM
It may take a little playing around to find what you like best. Most are in the 70-80* range. Some folks like a lower angle down in the 55-65. Typically the lower the angle the quicker the edge blunts. I think it will depend on whether you are you are using it for bulk removal or for just final light cleanup.
Karda
#3 posted 08-15-2017 05:29 PM
Thanks lee that gives me a starting point.
Here is a picture of a round scraper as requested.
View TheDane's profile
TheDane
5348 posts in 3534 days
#4 posted 08-15-2017 07:59 PM
- kaerlighedsbamsen
He is asking about scrapers used in woodturning on a lathe.
Karda
#5 posted 08-15-2017 11:20 PM
sorry should have been specific I forgot about card scrapers
View papadan's profile
papadan
3584 posts in 3240 days
#6 posted 08-15-2017 11:25 PM
Mike, I use card scrappers in turning. Helps smooth out bowls and plates when finishing.
View putty's profile
putty
1174 posts in 1478 days
#7 posted 08-15-2017 11:45 PM
- papadan
Well, that is interesting I’ll have to try that…thanks
-- Putty
View Nubsnstubs's profile
Nubsnstubs
1223 posts in 1601 days
#8 posted 08-15-2017 11:47 PM
Mike, my leaf spring scraper I made is at 65 degrees. Works great. What are you making it out of? ....... Jerry (in Tucson)
Karda
#9 posted 08-16-2017 03:20 AM
sorry Jerry I cheated I ordered a piece of 1095. after I cut it I have a 1 inch and a half inch . Now all I got to do is learn how to get them ot enough in the forge. I was going to try leaf spring but I decided to try a small piece I still have a lot to learn about just getting the bed of coal right, right now I am using wood not charcoal.
View Bill7255's profile
Bill7255
423 posts in 2156 days
#10 posted 08-16-2017 11:49 AM
- papadan
Well, that is interesting I ll have to try that…thanks
- putty
Card scrapers work well for removing small amounts of tear out. I use the all the time.
-- Bill R
Karda
#11 posted 08-16-2017 05:48 PM
how do you use card scrappers same as a turning tool
papadan
#12 posted 08-16-2017 11:13 PM
- Karda
Just like any other tool, just hold it tight and just below center.
View REO's profile
REO
927 posts in 1945 days
#13 posted 08-17-2017 12:03 AM
Hmmmmm scrapers are the only tool I am aware of INTENTIONALY presented below center. all tools can be used as scrapers, but the rest are intended to shear the chip. gouges at or above center. bedan at or above center. skew definitely above center. if presented at or below center on external turnings a scraper CAN have a 90 degree edge then for the interior present above center and you can avoid some traumatic although very exciting events!
Bill7255
#14 posted 08-17-2017 12:03 PM
I don’t use card scrapers with the lathe running!!!! Only with the lathe off to work small areas of imperfection.
-- Bill R
View Abter's profile
Abter
45 posts in 498 days
#15 posted 08-17-2017 04:31 PM
It may take a little playing around to find what you like best. Most are in the 70-80 range. Some folks like a lower angle down in the 55-65. Typically the lower the angle the quicker the edge blunts. I think it will depend on whether you are you are using it for bulk removal or for just final light cleanup.
- LeeMills
Newbie question: which angle goes with which purpose? In other words, is steep angle better for hogging or cleanup?
-- "Many men fish all their lives without ever realizing that it is not the fish they are after." {often mis-quoted as by H.D. Thoreau}
