Not getting a smooth epoxy finish
Forum topic by king_nickizzle posted 08-15-2017 02:29 AM 1497 views 0 times favorited 17 replies Add to Favorites Watch
View king_nickizzle's profile
king_nickizzle
25 posts in 1032 days
08-15-2017 02:29 AM
Topic tags/keywords: epoxy resin finish smooth wet sand
I’m using epoxy to go over a slab of black walnut. My first coat looked a little blotchy, so within the 5 hour window from the instructions, I added another coat. However, it’s still looking a little blotchy. Better, but still not perfect. It’s mainly trowel mark lines, brush lines, and things like that. I’ve seen videos where people pour the epoxy and it just levels out almost instantly whereas mine (properly mixed and stirred), will leave indents where the edge of the trowel or brush was.
I feel the third coat is going to do the same thing. Can I sand it all level as I would a normal piece of wood, and once level, work my way up to finer grits, ending in an 800 grit wet sanding? Or perhaps someone has a tip on how to get a better epoxy finish.
17 replies so far
View TheFridge's profile
TheFridge
10129 posts in 1606 days
#1 posted 08-15-2017 03:03 AM
I tried wet sanding epoxy to 2500. It didn’t work too well. If you want glossy you’re gonna have to pour it that way. I don’t know what you used but I hear west systems makes some great epoxy.
View Gilley23's profile
Gilley23
489 posts in 502 days
#2 posted 08-15-2017 03:34 AM
What kind of epoxy did you use?
TheFridge
#3 posted 08-15-2017 04:17 AM
I’ve only used bar too epoxy once and tried a variety of things to repair it with little success.
I just hear many speak of west systems when it comes to epoxy because it is versatile and a pretty reliable product.
MrUnix
6891 posts in 2319 days
#4 posted 08-15-2017 04:17 AM
Yup – what epoxy are you using? Neat epoxy (sans any fillers or additives) will flow pretty well. Sounds like yours is way too thick. You can decrease the viscosity for a better flow with heat… heating the epoxy and/or substrate you are applying it to will help.
TheFridge
#5 posted 08-15-2017 04:20 AM
king_nickizzle
#6 posted 08-15-2017 12:06 PM
Thanks for the responses! I’m using the brand Famowood. The reason i was thinking sanding would work in my case, is because I’m going for a matte finish anyway. I realize that if I want a high gloss, any sanding is going to scuff away that sheen. But since I’m going to be muting it quite a bit anyways, I figured sanding might be okay for this look. Here is an example of what some guys in town use, who use the same product I’m using.
http://decg5lu73tfmh.cloudfront.net/diyforums.net/images/fbfiles/images/traditional_trestle_bench_pine_top_with_matte_epoxy_v_1402774202.jpg
View LittleShaver's profile
LittleShaver
367 posts in 740 days
#7 posted 08-15-2017 12:47 PM
I had good results wet sanding up to 1200 then switching to auto buffing compounds. First a swirl remover than a polish. Used a HF 5” buffer for the auto compounds. There are auto compounds available that do not have silicone in them.
-- Sawdust Maker
king_nickizzle
#8 posted 08-15-2017 01:41 PM
Do you wet sand right from the start? Or do you sand it regularly with low grit in order to get it flat, and then move to wet sanding to really fine tune? I feel like getting it flat is going to take a while and using only wet sanding techniques will make the process even longer.
View Monte Pittman's profile
Monte Pittman
29797 posts in 2458 days
#9 posted 08-15-2017 02:19 PM
I have poured a fair amount of epoxy and never had blotches. Lots of other problems, but no blotches. It’s not completely self leveling. It will puddle and not flow. I use a plastic trowel to smooth it out. The warmer it is in the room makes a difference in viscosity when pouring and also how quickly it hardens. I don’t like brushes because you will wind up with bristles embedded in the epoxy.
Epoxy is a merciless teacher. Easy to make mistakes and very difficult to clean them up.
Good luck.
Monte Pittman
#10 posted 08-15-2017 02:21 PM
If you want something other than high gloss finish, I use spray lacquer over it for my sheen.
View tomsteve's profile
tomsteve
808 posts in 1339 days
#11 posted 08-15-2017 04:14 PM
- king_nickizzle
imo, wet sanding would be the way to go-using backing blocks to make sure the surface gets flat and sanding in different directions for each grit. sand in an ////// direction with one grit then\\\\\\ for the next. that helps to see that the scratches from each grit has been removed. you can keep going down( or is it up?) in grits until you achieve the sheen youre looking for. sandpaper grits go up to( or down to?) some seriously fine grits, which get called polishing paper after a point.
personally id start with 800 grit and see how that cuts and flattens. its easier to go down( or up?) to 400 if it isnt cutting fast enough then the other direction.
HOWEVER
IF there is anywhere that could possibly sanded through to bare wood, i would stick with dry sanding.
TheFridge
#12 posted 08-15-2017 04:20 PM
I was able to achieve a consistent matte by sanding with higher grits. I just couldn’t get any better than that.
View DS's profile
DS
2978 posts in 2541 days
#13 posted 08-15-2017 04:44 PM
I use micro mesh 5 in. discs to get a good polish. Once you get it flat, you are looking at a lot of work. Stepping through 1800 grit, 2400 grit, 4000 grit, 6000 grit, 8000 grit and finishing with 12000 grit. (No joke) Then applying a finishing compound.
Polishing compounds do something similar, but with less finesse and control.
I know you said you want a matte finish, but if you want to take it to a shine, lots of elbow grease is required.
Just FYI
View mitch_56's profile
mitch_56
20 posts in 593 days
#14 posted 08-15-2017 11:10 PM
Depends on what “blotch” means. Are you getting amine blush? Fisheyes? Might be best to post some pictures.
There are lots of things that can cause finish issues with epoxy, especially in shop and garage environments. Lots of surface contaminants can easily be deposited on your work, many people mix epoxy in containers that were previously used for all kinds of nasty stuff and then wonder why their epoxy looks like a train wreck. Oily hands, leaky compressors in the shop, spraying varnish or laquer nearby, porous or open-grained woods (like walnut) can cause air bubbles, even furniture waxes and car polishes—I’ve seen a million different things cause finish problems for epoxy over the years.
Sometimes guys use a propane torch to get rid of bubbles, but don’t use it well, and they scorch the epoxy. Some people mix their epoxy incorrectly and get too hot of a batch, or heat the part A too much (or heating the part B at all!) to make it flow better and the batch smokes as it cures – definitely going to get an ugly finish in those cases.
As for sanding, it can be done, but as mentioned above, it’ll take a fair bit of work, and you’ll have to go into some very fine grits and then polishing compounds, otherwise the finish will look dirty or hard to see through, sometimes hazy.
View Andybb's profile
Andybb
1231 posts in 724 days
#15 posted 08-15-2017 11:24 PM
If you r seeing trowel marks it could be that you are applying it too thick or is too thick to begin with. I would think that the blow torch or better yet a heat gun would be your best bet right after applying your third coat to get a smooth surface. I use either Total Boat or West System epoxy and have never had a problem.
-- Andy - Seattle USA
