Slippery Floor
Forum topic by John posted 08-15-2017 12:49 AM 970 views 0 times favorited 7 replies Add to Favorites Watch
View John's profile
John
8 posts in 689 days
08-15-2017 12:49 AM
I have a small shop, 12×16 I built myself. The problem I’m having is the floor is getting very slippery, to a point that feels unsafe. The floor is 1X12 southern yellow pine tongue and groove nailed with square cut nails. It’s on top of let paper sandwiched between the pine and 3/4 plywood sub floor on top of pressure teated 2×8 16” 0C. I sanded and cleaned the floor with a cleaner as recommended before I put Mono coat on it. It’s been fine for several years but now no matter what I do its slippery. I vacuum it, sweep it, wipe it down with a damp mop with a cleaner and it still seems slippery. Any recommendations appreciated. I’ve thought of using one of the items they use on hardwood floors that get slippery but wanted feed back first.
Thank,
John
7 replies so far
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#1 posted 08-15-2017 01:18 AM
Stop sweeping, mopping and wiping it :)
Or get some of these:
View Hermit's profile
Hermit
218 posts in 1566 days
#2 posted 08-15-2017 01:21 AM
You could try 1/4 cup vinegar with a gallon of water. Or, rustoleum males a nonslip spray. Or take Brad’s advise.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View TungOil's profile
TungOil
1088 posts in 736 days
#3 posted 08-15-2017 02:56 AM
I agree with you, if it feels slippery it is not safe.
We used to add a non-slip grit to the paint for boat decks. It was like a very fine sand mixed with the paint. You might be able to use that mixed with a urethane floor finish. If I recall correctly it was made by Petit.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View TheFridge's profile
TheFridge
10818 posts in 1727 days
#4 posted 08-15-2017 03:04 AM
Sand and a varnish for the cheap route.
View GR8HUNTER's profile
GR8HUNTER
5400 posts in 953 days
#5 posted 08-15-2017 03:08 AM
change your shoes maybe :<))
View Gilley23's profile
Gilley23
489 posts in 623 days
#6 posted 08-15-2017 03:32 AM
I’d pick up a gallon of varnish and a little bit of sand and a bucket to mix them in. Mix well and apply to your floor.
View Sparks500's profile
Sparks500
207 posts in 571 days
#7 posted 08-15-2017 12:16 PM
If you varnish your floors, add some of this:
I use it in the clear sealer for my patio
-- A good day is any day that you're alive....
