How to secure live edge slab to a steel base?
Forum topic by ModernWoodWorkz posted 08-13-2017 11:43 PM 404 views 0 times favorited 4 replies Add to Favorites Watch
View ModernWoodWorkz's profile
ModernWoodWorkz
7 posts in 297 days
08-13-2017 11:43 PM
Hey guys. I wanted to ask how each of you are connecting a live edge slab to a steel base to account for expansion.
I’ve seen a couple photos from the internet but if anyone can lay down specific details it would be greatly appreciated.
Thank you in advance.
runswithscissors
2654 posts in 1930 days
#1 posted 08-14-2017 04:01 AM
I glued up a “slab” for a coffee table because I didn’t have wide enough boards. This was from a beech I’d taken down several years before. I made up legs with stretchers from 1 1/2” pipe. Instead of using pipe flanges (which seemed too big for the scale of the table) I welded square plates to the tops of the legs. When I first screwed them in place, a crack started forming very soon. So I filed the screw holes into an oblong shape and refastened, leaving the screws just snug enough to prevent wiggling, but not so tight as to prevent wood movement. The incipient crack then went away, and it has worked fine since.
The slab is not reinforced with an apron. This doesn’t seem to be a problem
View jerryminer's profile
jerryminer
888 posts in 1346 days
#2 posted 08-14-2017 04:39 AM
Screws in slotted holes is my go-to solution.
View Loren's profile
9948 posts in 3553 days
#3 posted 08-14-2017 04:51 AM
The easiest approach imo is to attach two
battens with slotted screw holes to the
bottom of the slab. Then the batten ends
can be fastened to the base. The method
avoids making slotted screw holes in steel.
View William Shelley's profile
William Shelley
538 posts in 1374 days
#4 posted 08-14-2017 11:31 PM
Use a 3/4” NPT tap to tap a blind hole directly into the slab, if it’s thick enough. Assuming your ‘steel base’ is iron plumbing pipe.
-- Woodworking from an engineer's perspective
