Breadboard screw up
« back to Joinery forum
Forum topic by Shirk99 posted 08-13-2017 10:06 PM 635 views 0 times favorited 2 replies Add to Favorites Watch
View Shirk99's profile
Shirk99
3 posts in 404 days
08-13-2017 10:06 PM
Topic tags/keywords: breadboard monetise tenon
Newbie woodworker here. I am trying to make a hope chest for my step daughter using breadboard ends on the top. I glued only the center tenon but forgot to put the dowel holes in first… any ideas how to fix this now?
2 replies so far
View SuperCubber's profile
SuperCubber
1036 posts in 2402 days
#1 posted 08-14-2017 01:59 AM
Not sure this is the best solution, but it could work:
Drill out the elongated holes on the sides through the top layer of the bread board and the tenon. Glue a short dowel to the bottom layer of the bread board only, then drill a larger, round hole on top and “plug” it with a larger dowel.
Hope that makes sense!
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
Shirk99
3 posts in 404 days
#2 posted 08-14-2017 06:08 AM
Thanks I think I will try that. I started the process…I drilled the elongated holes on the underside and put small dowels through the top. Wasn’t real sure the best way to plug them but I like your idea.
Thanks again
