Wet Sharpeners and Antifreeze
Forum topic by TomHintz posted 01-12-2011 10:00 PM 1404 views 0 times favorited 19 replies Add to Favorites Watch
View TomHintz's profile
TomHintz
207 posts in 3272 days
01-12-2011 10:00 PM
I am in the process of doing a test mixing antifreeze with the water that saturates my JET Slow Speed Grinder stone wheel. I keep getting email on this and nobody seems to know much about it though many are more than willing to theorize.
I decided to give it a whirl and right now my JET stone grinding wheel is saturated with a 50% mixture of water and Sierra brand antifreeze. This brand claims to be “safer” for people and animals yet shows remarkable freeze protection down to temperatures that really should be off of the woodworking scale of probability.
So far the wheel has been saturated and re saturated with the antifreeze/water solution and nothing has happened to the stone. It still grinds fine, hasn’t gone soft and despite being set directly in front of a hole in the garage door in my unheated shop, hasn’t been bothered by temperatures (measured at the grinding wheel) of 18-degrees so far.
If anyone has tried this and has first hand information I’d like to hear it! Email me at thintz@newwoodworker.com.
-- Tom Hintz, www.newwoodworker.com
19 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3587 days
#1 posted 02-04-2011 06:43 AM
Might the chemical that makes the antifreeze effective react badly with the binding agents in the grindstones?
TomHintz
#2 posted 02-04-2011 10:15 AM
I’ve been updating the original story and it shows that even with re-saturating the wheel with the antifreeze solution, the stone has not softened or done anything that I can tell. It still sharpens the same and grades the same. Remember that this is all being done with a JET stone wheel. I have not tested any other manufacturers wheels. (and won’t, this one cost enough!)
View Gene Howe's profile (online now)
Gene Howe
9934 posts in 3302 days
#3 posted 02-04-2011 01:41 PM
Sounds like a plan, Tom. Good idea.
TomHintz
#4 posted 02-04-2011 01:48 PM
Here is a link to that story. I thought I had done this earlier but my age is hanging out again and I forgot, or something.
http://www.newwoodworker.com/basic/wtrizstnwhels.html
View Derek Lyons's profile
Derek Lyons
584 posts in 3442 days
#5 posted 02-04-2011 07:54 PM
It’s hard to tell what the effects will be over months and years… A week is nothing.
-- Derek, Bremerton WA --
TomHintz
#6 posted 02-04-2011 07:58 PM
A week was nothing but that was at least three weeks ago and I have been resaturating the stone every other day, sometimes everyday just to be sure it is alwayssoaked with the antifreeze solution. In a year I’d probably have the stone wore out anyway as much as I use it.
Derek Lyons
#7 posted 02-07-2011 11:00 PM
I’m curious as to how much gets thrown into the air… What does the MSDS have to say on the antifreeze ingredients?
View juniorjock's profile
juniorjock
1930 posts in 3639 days
#8 posted 02-08-2011 12:00 AM
Could you use the wind shiled cleaner that you use for your car?
- JJ
View ajosephg's profile
ajosephg
1880 posts in 3435 days
#9 posted 02-08-2011 12:06 AM
Windshield cleaner is essentially methanol and water and some blue dye. As a result it evaporates rapidly so it wouldn’t work very good with a grindstone.
-- Joe
View DrDirt's profile
DrDirt
4418 posts in 3616 days
#10 posted 02-08-2011 01:13 AM
The stone will be fine in the antifreeze. A lot of manufacturers are switching from Ethylene Glycol to Propylene Glycol because it is less poisonous. Just one carbon longer…
Just like Methane (1 carbon) Ethane (2) Propane (3) or Methanol, ethanol, propanol
Regardless – the binding agents remaining in the stones are completely inorganic, There are usually also organic binders that are blended with the particles to make them stick together under the press, but then are burned off as the stones are sintered. Basically the same kind of process turning clay into ceramic/brick – the particles are sintered together.
juniorjock
#11 posted 02-08-2011 01:28 AM
Thanks for the info, Joe… I learned something.
View rance's profile
rance
4255 posts in 3034 days
#12 posted 08-12-2011 10:44 PM
If it is 18° in the shop, then its time to get a heater, or go do something else. Adapt the shop to the worker, not the worker & tools to the shop. :)
TomHintz
#13 posted 08-12-2011 10:49 PM
Just for grins when the last response was posted (WAY late!) I went out and checked the stone that has been saturated with the antifreeze ever since all this started. I put it in a sealed plastice bag ahen I got tired of saturating it every day and as of 10 minutes ago it is still nice and hard, just like before I started saturating it with the antifreeze. I’m thinking that it is going to be OK.
View WayneC's profile
WayneC
13751 posts in 3971 days
#14 posted 08-13-2011 06:55 AM
If it was automotive anti freeze it was highly toxic to pets if ingested. I would check that out if you have any pets that have access to the shop..
TomHintz
#15 posted 08-13-2011 08:07 AM
I have gotten tons of email on this topic over the years and finally decided to tri it out for myself. People say the stone will dissolve, it will gum up, it iwll quit sharpening, all sorts of stuff. None of it turned out to be true with the antifreeze I used. Rather than gfo through all of this again here I’ll pout a link to the sgtory below.
