Drum sander
Forum topic by jimbrown posted 08-13-2017 07:18 PM 535 views 1 time favorited 2 replies Add to Favorites Watch
View jimbrown's profile
jimbrown
22 posts in 491 days
08-13-2017 07:18 PM
I needed a drum sander to make 3/32 slabs for Shaker boxes. My shop is small and not able to accommodate a big separate unit. I found a pattern in the internet and adapted to my use. The base is a 4” sch 40 plastic pipe, mounted between 2 pillow blocks and driven on the top of my table saw. I removed the saw blade, mounted a pulley, rerouted the electric switch and used left over ply scraps. Total cost was under $75.00. It works well and now I can make my Shaker boxes as well as sanding anything under 12” wide.
-- JimBrown
2 replies so far
View Redoak49's profile
Redoak49
3655 posts in 2185 days
#1 posted 08-13-2017 09:23 PM
Very nicely done…
View Desert_Woodworker's profile
Desert_Woodworker
1631 posts in 1411 days
#2 posted 08-14-2017 01:42 AM
Good job – may I suggest that you post it on “projects”....
-- Desert_Woodworker
