Question Answered
« back to Coffee Lounge forum
Forum topic by jbay posted 08-13-2017 05:23 PM 736 views 0 times favorited 15 replies Add to Favorites Watch
View jbay's profile
jbay
2289 posts in 898 days
08-13-2017 05:23 PM
Thanks to everybody that answered.
15 replies so far
View Desert_Woodworker's profile
Desert_Woodworker
1355 posts in 1213 days
#1 posted 08-13-2017 07:26 PM
Can you attach it to the interior of the pocket door frame?
-- Desert_Woodworker
View jbay's profile
jbay
#2 posted 08-13-2017 08:59 PM
No Desert, this is not a typical pocket door installation. It’s framed out using steel square tubing.
The contractor re-did it twice using typical wood framing before switching to steel and won’t let me touch it.
Thanks for chiming in.
Desert_Woodworker
#3 posted 08-14-2017 01:45 AM
Is it constructed of- Maple or Alder? :)
View jbay's profile
jbay
#4 posted 08-14-2017 01:54 AM
- Desert_Woodworker
Hard Alderple!
Desert_Woodworker
#5 posted 08-14-2017 02:01 AM
- Desert_Woodworker
Hard Alderple!
- jbay
Regardles, it is fine construction!
View TungOil's profile
TungOil
936 posts in 494 days
#6 posted 08-14-2017 02:04 AM
Looks really nice jbay. At 9’ tall do they go right up to the ceiling? I like the doubled shelves, gives them a nice substantial look.
-- The optimist says "the glass is half full". The pessimist says "the glass is half empty". The engineer says "the glass is twice as big as it needs to be"
View jbay's profile
jbay
#7 posted 08-14-2017 02:19 AM
Thanks TungOil,
Yes, they will be going to the ceiling.
I’m going out to the house with a template to scribe the ceiling, then bring the template back to the shop and transfer to the cabinets. That way I can make the cuts in the shop. Then when I install I won’t be dragging heavy cabinets in and out of the house to fit them.
Desert, they are built using maple hardwood and plywood.
Unit will be painted black to match the Sliding pocket door that will be next to it.
All of the shelf heights match the rails on each panel of the pocket door.
Desert_Woodworker
#8 posted 08-14-2017 02:46 AM
pt2 (respectfully)
Let’s talk about the span, of each carcass- aprox. 30-36” in length? If so, it appears that you have made a “glue-lam” beam of a shelf to span this distance.
Genius, if it can carry the weight load of a span over 30”, if so how many pounds, before it “bows”? What I don’t see is- how do you, attach the face frame to the shelf, or not?
View AlaskaGuy's profile
AlaskaGuy
4136 posts in 2308 days
#9 posted 08-14-2017 05:30 AM
Thanks for sharing
View jbay's profile
jbay
#10 posted 08-15-2017 12:37 AM
Thanks AG
Desert, 32” span.
It should hold whatever is going to be put on them. I don’t know how many lbs.
The front has the solid piece of maple applied to it and they will all be screwed to the back as well.
Should be plenty strong.
The shelves won’t be attached to the face frame.
Here is the sagulator specs. (without the shelves screwed to the back) and if I did it right.
Desert_Woodworker
#11 posted 08-15-2017 01:41 AM
Those shelves are solid- I hope that you post more of this type of information. You include the drawings and tech data.
Good job ,
As an aside :) Why “sugar maple” ? I thought that Alder was the rage on Lumber Jocks ….
View sawdustdad's profile
sawdustdad
354 posts in 884 days
#12 posted 08-15-2017 02:00 AM
You can attach it to the back wall above the door—there is a header there and studs beyond the door pocket.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
View jbay's profile
jbay
#13 posted 08-15-2017 02:18 AM
- sawdustdad
This is a custom home.
The pocket door is 7’ wide and goes all the way up to the ceiling. No header or studs.
The framing for the pocket door is steel square tubing and the contractor is not going to let me screw into it.
View jbay's profile
jbay
#14 posted 08-15-2017 02:20 AM
Good job ,
As an aside :) Why “sugar maple” ? I thought that Alder was the rage on Lumber Jocks ....
- Desert_Woodworker
Alder IS all the rage, I love it!
But Maple was the better choice here.
(different quality for different price range)
They are paying for higher quality.
Heck, I could have used mdf and poplar and it would have looked just the same.
View jbay's profile
jbay
#15 posted 09-08-2017 03:16 AM
Here is the finished bookshelf – installed.
The framed door with the glass panels, (on the right in the second picture),
is the full floor to ceiling pocket door. Thus the reason I could not screw into the back wall.
Unit was screwed to ceiling and glued to a platform with adhesive and shims, then covered with a 1 3/4 high kick.
