Help with solvent for sanding disc glue
Forum topic by Shopsmithtom posted 274 days ago 196 views 1 time favorited 8 replies Add to Favorites
View Shopsmithtom's profile
Shopsmithtom
258 posts in 723 days
274 days ago
It seems that I need to tap the collective wisdom of the group yet again. I’ve been using self stick 12” sanding discs on my disc sander and the last couple of times, after replacing them I haven’t needed to remove the residue (maybe should have, but it was evenly dispersed, so I just applied the new disc), anyway after removing the last sanding disc, I decided this rubbery (has the look of dried contact cement) residue is too gucky and uneven to leave.
I’ve tried lacquer thinner and mineral spirits (it’s not water soluble) and they do seem to make it stickier, but short of soaking the disc in a tub of either of them for a long time, I’m looking for something that acts quickly.
A haven’t got any acetone here to try & I may just go buy some, but I was wondering if anyone has any other ideas.
Thanks -SST
-- Accuracy is not in your power tool, it's in you
View GaryK's profile
GaryK
8541 posts in 516 days
274 days ago
Use MEK (methyl ethyl ketone). Get it at Home Depot or Lowes where you find acetone and paint thinner.
Works great for adhesives. Will get it off for sure.
Douglas Bordner
2707 posts in 592 days
274 days ago
I would think acetone would be the way to go.
View Tim Pursell's profile
Tim Pursell
217 posts in 310 days
273 days ago
If you can warm it up with a heat gun (or the wife’s hairdryer if she’s not home) most of the residue should scrape off with a metal putty knife. I’m surprised laq. thinner did not remove it, thats what I have used in the past.
-- http://www.grandprairiewoodworks.com
Shopsmithtom
273 days ago
I’ve tried the heat gun, and it simply gets stickier and ultimately dries tougher. This stuff is unbelievable. I’ll try acetone first since I just bought some, and then head to the store for MEK. Thanks everyone.
GaryK
273 days ago
I think that the acetone will eventually get it off, but mostly it will make it gummier and move
it around a lot.
Let us know what your results are.
Shopsmithtom
273 days ago
I tried some naptha. I set the disc flat and poured some on and kind of smeared it around to cover the guck. I then let it sit for about a half hour and it softened enough to scrape it off with a putty knife. I then put a little more on a scotchbrite pad and rubbed around &it all came off.
I don’t think I’ll let it get that bad again -SST
View jeffthewoodwacker's profile
jeffthewoodwacker
202 posts in 332 days
273 days ago
Try acetone or Goo Be Gone.
-- Genius is immediate, but talent takes time.
View Tom Adamski's profile
Tom Adamski
225 posts in 299 days
273 days ago
SST,
I have had great luck with 3M General Purpose Adhesive Cleaner. You can find it at the big box stores and at specialty automotive stores, like NAPA (where I get it). It is about $15 per quart and it works very well. Scrape the disc as clean as you can and then apply cleaner with a rag.
When done, let the rags dry completely outside, away from anything combustible. As always, protect yourself; use goggles, respirator and heavy duty gloves (thin latex gloves will melt).
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
Bookmark And Share This Page
