Craftsman style medicine cabinet
Forum topic by Brian Grabast posted 08-13-2017 01:54 AM 1787 views 0 times favorited 26 replies Add to Favorites Watch
View Brian Grabast's profile
Brian Grabast
15 posts in 1249 days
08-13-2017 01:54 AM
Topic tags/keywords: craftsman medicine cabinet
I want to build a craftsman style medicine cabinet. I have found a picture of one I like but can’t find any plans. Is there somewhere I can buy or get free plans? I don’t mind buying plans if I can find what I want.
-- Brian, Olathe KS --- Remember you're only one oops away from expensive firewood.
26 replies so far
View AlaskaGuy's profile (online now)
AlaskaGuy
4782 posts in 2509 days
#1 posted 08-13-2017 06:41 AM
Show us the picture of the one you like. It could save a lot of time if someone helps you search for a plan.
Brian Grabast
#2 posted 08-13-2017 04:56 PM
Here is a photo of one my wife likes. I could probably figure out how to do this without plans but I would like plans to get proportions of the different pieces. Especially the top with the corbels and the door frames.
Thanks for the help.
View Madmark2's profile
Madmark2
405 posts in 788 days
#3 posted 08-13-2017 05:22 PM
Buy the mirrors first! … all else depends on their dimensions.
M
AlaskaGuy
#4 posted 08-13-2017 05:22 PM
Surface mount or recessed into the wall
View Rich's profile (online now)
Rich
3878 posts in 789 days
#5 posted 08-13-2017 05:26 PM
M
- Madmark2
I buy my glass from a custom shop. He can make any dimension, dual or single pane, you name it. He also does mirrors and bevels. I’m sure most cities have such a business, if not, you can order online.
Buying the glass first and building a cabinet around it is backwards.
AlaskaGuy
#6 posted 08-13-2017 05:36 PM
M
- Madmark2
Good point. You can order custom cut beveled mirrors to fit your needs.
Madmark2
#7 posted 08-13-2017 05:38 PM
So you want to pay full bore for custom work instead of a stock blank? Glasswork isn’t as precise as woodwork typically 1/4”. You’ll get better results with glass in hand than without. Get the glass, get the actual dims and build to fit. You can then drop in the mirrors at the end of the project and be done instead of taking your final dims and waiting a week for mirrors that might fit. Yeah this is backwards but better.
M
View jbay's profile
jbay
2865 posts in 1099 days
#8 posted 08-13-2017 05:43 PM
I’ve order hundreds of pieces of glass,
I would build what I want with the measurements and proportions I want then order glass to fit.
I would not let a stock blank (if there is such a thing) dictate the size of my cabinet.
Rich
#9 posted 08-13-2017 05:46 PM
So you want to pay full bore for custom work instead of a stock blank? Glasswork isn t as precise as woodwork typically 1/4”. You ll get better results with glass in hand than without. Get the glass, get the actual dims and build to fit. You can then drop in the mirrors at the end of the project and be done instead of taking your final dims and waiting a week for mirrors that might fit. Yeah this is backwards but better.
M
- Madmark2
You need to work with better suppliers. My guy gets it exact and his prices are excellent. If he didn’t, I’d find someone who did. An exception might be if you had panels in hand that you wanted to use, then there’d be no other option.
AlaskaGuy
#10 posted 08-13-2017 06:46 PM
Anyway back to the OP, this would be pretty easy to make your own plan. Its a nutshell it a box with a face frame, inset doors and and a little ginger bread.
For proportions ? Depends, the depth of the cabinet if recessed the wall cavity will pretty much dictate depth unless you want it to stand proud of the wall for some reason . Overall size I’d start with roughly the golden mean and see where that gets you. Style and rails you can make mock ups out of cardboard until you get what you want. You could easily mock-up the whole front with cardboard.
If its surface mount it can be anything you like but I wouldn’t make it to deep. Figure out what you want to put in it and go from there. Unless you live out in a remote place there are plenty of medicine cabinets store to look at for sizes and depth.
It could be a good learning process for you.
View Woodknack's profile
Woodknack
12430 posts in 2579 days
#11 posted 08-13-2017 07:34 PM
- BrianG0714
There isn’t a plan for everything so you’ll have to do some legwork (or find a plan that you like). One old school way to get your measurements from a photo is using dividers but it requires you know one dimension. (all numbers ahead are made up) For sake of argument say the overall width of the cabinet is 30”. Print the photo and set your dividers or compass to the height and step it off across the known width. Let’s say the height is about 2/3 the width, so that’s 20”. Next set the dividers to the stiles, walk them across the cabinet width, and say it’s 6.5 steps or about 4-5/8”. That way you can get your measurements. (Note: because of the angle of the cabinet in the photo, this will only be an approximation but it’ll be close enough)
Brian Grabast
#12 posted 08-13-2017 09:37 PM
I already have mirrors and I have a medicine cabinet I’m replacing. So I can get depth, height and width. Because it’s on an exterior wall it can’t be recessed. I can figure out everything on my own but it is easier with plans. The only things I’m not sure about I guess is the piece above the doors and how wide the top is. Does the piece above the door just sit in a notch in each side? This is only my fourth large project since I was out of high school, which was longer ago than I can remember, so I just feel better if I have plans. Even if I don’t make it the exact size of the plans. I will try to figure this out and I will end up with a nice medicine cabinet or expensive firewood. I’m assuming the top is 3/4 stock so I can figure out some dimensions based on that.
AlaskaGuy
#13 posted 08-13-2017 10:25 PM
I already have mirrors and I have a medicine cabinet I m replacing. So I can get depth, height and width. Because it s on an exterior wall it can t be recessed. I can figure out everything on my own but it is easier with plans. The only things I m not sure about I guess is the piece above the doors and how wide the top is. Does the piece above the door just sit in a notch in each side? This is only my fourth large project since I was out of high school, which was longer ago than I can remember, so I just feel better if I have plans. Even if I don t make it the exact size of the plans. I will try to figure this out and I will end up with a nice medicine cabinet or expensive firewood. I m assuming the top is 3/4 stock so I can figure out some dimensions based on that.
- BrianG0714
All the information would have been very helpful had it been it your first post.
Woodknack
#14 posted 08-14-2017 04:55 AM
Basically what you have is a 5 sided box with front + moldings. So everything you see in front is separate from the box behind it. Top and corbels are added last.
Brian Grabast
#15 posted 06-26-2018 06:52 PM
After a year I have finally finished the medicine cabinet. I bought some hinges locally not thinking about the weight of the door with a mirror (beginner’s mistake or not thinking ahead or both). When I hung the door I couldn’t get it to hang with the same reveal all the way around the door. Then I realized the pin in the top hinge had bent from the weight. Does anyone know where I can order hinges that will hold the weight. The doors are oak with about a 2” frame and about 23” x 27” with a mirror about 21” x 25”. Not extremely heavy but more than cheap hinges can hold.
