| Forum topic by trainwreck | posted 862 days ago | 827 views | 0 times favorited | 28 replies | ![]() |
862 days ago |
So I’m a newbie woodworker building furniture from dimensional lumber. I don’t have a garage, so I haul my tools outside to build. Not a huge deal when making cuts or sanding or finishing, but it’s a monstrous pain in my backside to put this stuff together and get it square. The ground is not level, so I basically end up carting everything to my neighbor’s patio since it’s concrete and level. Thankfully, they don’t mind and quite enjoy the entertainment. My question is is there something I can do or put down on the ground or my picnic table to make this easier? |
28 replies so far
#1 posted 862 days ago |
Hi – you could make a torsion box with two pieces of 3/4 MDF and 2 by lumber. with some wedges to level it over the ground it would give you a great reference for level. It will be heavy so you do need someplace to store it and a way to move it (and keep it dry). Lighter materials would probably work but I would investigate the MDF option first as the stuff is so inherently flat and stiff. On one of my posts I presented a mobile fold up workstation that you might want to look at – it was designed for someone without a shop and could fit your bill for some things as well. Good luck -- DonH Orleans Ontario |
#2 posted 862 days ago |
Bad humor- I would have my wife get a second job so I could afford to build a shop. Then she could use the shop to make my casket. -- Regret- the feeling you get just after you do something really stupid. |
#3 posted 862 days ago |
Well, I don’t have a lot of stuff, so it’s stored in my cramped shed (8×10), and I just haul out my tools when I want to build something. I have a tote thing that I use to hold my tape measure, screws, bits, glue, etc. The circular saw, jig saw, drill, and ROS just get hauled out one by one. I do have a picnic table that doubles as a sort of work bench. It works great for cutting—I just clamp the wood to it and then clamp a square to the wood, then cut, but it sucks to build anything on it because it isn’t a level surface which makes it nearly impossible to keep square. I’m a single mom, so my budget is limited. There are many, many days that even though I don’t “play for that team,” a wife sounds pretty good! LOL The torsion box sounds intriguing…..off to check that out! |
#4 posted 862 days ago |
What to put on the ground: Try crushed granite, it’ll pack down to a pretty hard surface. It won’t be as hard or smooth as concrete but it’s cheaper if that’s a factor. For leveling freestanding shelves and some tools I make try T-nuts with carriage bolts, -- Darrell, making more sawdust than I know what to do with |
#5 posted 862 days ago |
Hollow-core doors are pretty flat – flat enough for an assembly surface. A solid workbench is the most essential tool in most furnituremaking. Built My old Workmate has leveling feet on it. I don’t know if newer models do. I’ve worked on hellish ground myself, and eventually at that crazy cabin |
#6 posted 862 days ago |
Yeah…I think in a couple years when I have a garage, one of my first things will be to build a torsion box work bench. I’m almost wondering if I could get by with just a sheet of MDF clamped to my picnic table. My issues are all with assembly and not having a flat surface to work on. I may just try that, and if it doesn’t work, that sheet of MDF can become part of the torsion box. My dad had an old Workmate. I wonder if that’s still in his garage. I may just have to play the “daddy’s little girl” card (never mind that I’m 40! It still works!) and bring it home with me! LOL Would it work to make a torsion box with folding legs? (like a card table). I could put some of those leveling thingies like for a washer or dryer on the legs to level it out. |
#7 posted 862 days ago |
move into your neighbor’s garage -- Bert |
#8 posted 862 days ago |
A torsion box with folded legs would work fine. On the other hand as per Loren’s suggestion, a door is good as a first step and a lot lighter. I have often used a 32 inch door on a pair of saw horses as a work bench outdoors for really dirty jobs and that works fine. Just shim the saw horses to level. Upon reflection my suggestion of the torsion box may be overkill. Try the door and go from there. Don -- DonH Orleans Ontario |
#9 posted 862 days ago |
Your best bet may be to attach a fold down workbench to the side of your shed. Easy to put away and get out and would only need 2 legs to keep it level. Maybe even attach a lean to type roof off of the side of the shed to keep the sun from beating down on you while your working. -- I don't make mistakes, I have great learning lessons, Greg |
#10 posted 862 days ago |
I have a shop but due to the cold weather and no heat in the shop I have had to move a lot of my work inside my house. I will do my gluing, clamping and other bench work like that on my kitchen table. I have a sheet of MDF that I put over the table to protect it. Can be a little messy but it works. -- Dan - "Collector of Hand Planes" |
#11 posted 862 days ago |
I see you’re in MN so outdoors is a challenge this time of year. The hollow core door on saw horses is a dandy way to start. I made a couple of those when I built my house 30 years ago and still use them. You can sometimes pick up one those doors at salvage places for almost nothing; especially when they get a ding or hole poked in them. You only need one good side to use as a work surface. It’s also a good idea to cover the working surface of the door with 1/4” or 3/8” MDF to make it more durable. 3/4” MDF will work for sure, but it is very, very heavy. I like to seal the MDF with a couple of coats of BLO (boiled linseed oil) and varnish or polyurethane so it won’t soak up moisture and swell up. The BLO mixture is better in my opinion as it’s not too slick. -- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason. |
#12 posted 862 days ago |
Get one of those canvas car garage they are cheap and very easy to put up. |
#13 posted 862 days ago |
Pour you a concrete pad that you could work on. In the mean time work on that. Next step put up some posts and a roof to keep the sun and rain off. Work under that for a while. Then put three walls on it and work in that for while. Finally, finish the fourth side with walk through and roll up door. After that your all most there. You could do it over three or four years and always be moving towards a finished shop. I worked in my carport (which is now my shop), my driveway, and in the back yard for a good many years. I’m 60 now. It was only six maybe seven years ago that I finally closed in my carport. There was an old two door wardrobe under the carport that I kept my tools in. You do what you have to do. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#14 posted 862 days ago |
Like Dan said, my wife would occasionally let me do some work in the kitchen when it was really cold outside. -- If a man does not keep pace with his companions, perhaps it is because he hears a different drummer. Let him step to the music which he hears, however measured or far away. Henry David Thoreau |
#15 posted 862 days ago |
Single mom???? OK, forget my bad attempt at humor! With all the folks here on LJs, we’ll come up with a bunch of solutions. Just pick the one that fits the need. Let us know how things work out. -- Regret- the feeling you get just after you do something really stupid. |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15793 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
