Help identify wood species
Forum topic by Tm125690 posted 08-12-2017 04:26 PM 685 views 0 times favorited 23 replies Add to Favorites Watch
View Tm125690's profile
Tm125690
2 posts in 285 days
08-12-2017 04:26 PM
Hello, can anyone please help me identify a wood species on a table that I am refinishing. I am new to refinishing, and to woodworking in general. My wife bought this table from a neighbor, they said it is from Pottery Barn. I have stripped and sanded it to bare wood, and would like to determine the wood species before I stain and finish it, as I understand this will influence how I go about these processes. Many thanks in advance for any assistance.
Tim
23 replies so far
View TheFridge's profile
TheFridge
9454 posts in 1483 days
#1 posted 08-12-2017 06:31 PM
I think it’s alder. About 100% sure.
View Desert_Woodworker's profile (online now)
Desert_Woodworker
1355 posts in 1211 days
#2 posted 08-12-2017 07:33 PM
Fridge- you beat me to again- Alder
-- Desert_Woodworker
TheFridge
#3 posted 08-12-2017 07:59 PM
Tm125690
2 posts in 285 days
#4 posted 08-12-2017 08:09 PM
Thank you so much for your help!! From my initial reading it sounds as if I will still want to use a pre-stain conditioner. (Planning to use general finishes water based Pre-stain conditioner, general finishes water based wood stain, and then 4-5 coats of waterlox to finish it).
I will post photos after staining/finishing!( though this will take about 2 weeks until I get a chance to stain it).
Thanks so much,
Tim
View Aj2's profile
Aj2
1387 posts in 1794 days
#5 posted 08-12-2017 10:42 PM
Wait a minute cowboy you said the table was purchased at the pottery barn .
My guess is rubber wood.
-- Aj
Desert_Woodworker
#6 posted 08-12-2017 10:50 PM
Does “rubber wood” come in Alder?
TheFridge
#7 posted 08-13-2017 12:42 AM
I believe it does.
View Tony_S's profile
Tony_S
867 posts in 3079 days
#8 posted 08-13-2017 10:16 AM
- Aj2
Yep.
Pottery Barn screams ‘not domestic’. Looks like Rubberwood to me as well.
http://www.hobbithouseinc.com/personal/woodpics/rubberwood.htm
AKA…Fridgea Alderiliensis
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View ChefHDAN's profile
ChefHDAN
1062 posts in 2846 days
#9 posted 08-13-2017 11:03 AM
AND… it’s a royal bi+ch to stain, I just used a part of a table top i salvaged from what someone was dumping that was the same wood. I had to do it over because of how it will absorb the stain. Be very meticulous with your sanding, I hand sanded a few places after finishing up with the ROS and those spots were very noticeable. If I don’t put the rest of the table top into the fire pit, I’ll use a gel stain next time and blend the color a bit better. There are several LJ’s here with more experience than I do they might recommend dewaxed shellac first, but I’ve never used and can’t offer any tips there. You might want to start another thread for staining rubber wood and get some advice from Charles Neil.
View splintergroup's profile
splintergroup
2010 posts in 1219 days
#10 posted 08-13-2017 02:17 PM
I would have guessed alder 8^)
With something like that with questionable staining qualities, I’d go for a sealing with shellac and then color it with toners mixed in with a clear topcoat.
View sawdustdad's profile
sawdustdad
354 posts in 882 days
#11 posted 08-14-2017 12:55 AM
If it’s from Pottery Barn, no telling which tropical wood it might be, it’s whatever grows in the Philippines…or India…or Mexico… and it’s whatever they had on hand that day at the factory.
Doesn’t matter what wood it is. It’s not a valuable hardwood, so knowing the exact species is kind of superfluous, right? How would knowing the species matter to your finishing routine? Pick a stain you like, apply and see what happens.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
Desert_Woodworker
#12 posted 08-14-2017 01:17 AM
Wow! I never heard of such a thing as “Rubber Wood” – Again, Aj2 you are the Meister…
TheFridge
#13 posted 08-14-2017 02:22 AM
I believe rubberwood is just a sub-species of alder with the same working characteristics as the parentwood because of the predominant parenchyma bands in the margins around the pores where they meet the medullary rays.
View Aj2's profile
Aj2
#14 posted 08-14-2017 02:40 AM
Haven’t lost a wood I’d yet.
Except for the Alder one :)
-- Aj
TheFridge
#15 posted 08-14-2017 02:44 AM
Me neither. Because everything is a sub species of alder. The first wood ever discovered.
